TE/TC 4CS Issues
Discussion in '2st' started by Lincolnlock, Dec 7, 2014.
  1. Huskyfatman Husqvarna
    So.Nv.
    I had a 2000 TE610 with 45mm Zokes and stock they were crazy soft yet somehow harsh. Had RG3 valve and spring them for me and they were much better but still harsh compared to the KYB Japanese bikes at the time (YZ426/KX500) and my old '95 Husky with Showas. I rode my buddies '01 TE570 and the forks seemed similar to my '00. The 45's on the '08 TE610 are pretty good stock though, so it seems they got better.
    MY '14 Berg 300 still needs the 4CS' sorted but they seem a better starting point than my old '00 Zokes. Stiffer springs helped mine with the full compression deflection they seem to have by keeping higher in the stroke, but sharp edge g-outs still get sketchy. They'll probably find their way to Zip Ty's.
  2. bowser Husqvarna
    FE350
    put about 120km on the forks with the latest mods today (stock parts) with some internal changes, man they are so much better, I didn't mind them originally but high speed hits shook my bones, they are plush now, ride really high in the stroke and resist bottoming good.
    I had a crf with revolved showa's previously which was great for woods, I would rate the 4CS as good if not better than these now.
    front end traction is on another level now, only downside if both legs now only have comp adjustment on the top, rebound is fixed
  3. mike243 Husqvarna
    2012 wr 300 FOR SALE
    yz 450 ( built to go fast) yamaha R1
    so now you have compression on the top and rebound on the bottom ? is that the fix with these forks ?
  4. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Some folks sent their forks to suspension shops and they added base valves basically turning the forks into open chamber style but Bowser is commenting on his personal reconfiguration method which uses existing parts assembled differently causing the adjusters on the top to affect compression only. He doesn't have base valves with that setup. Clear as mud right?
  5. bowser Husqvarna
    FE350
    thats right Reveille, both top adjusters are comp now and have no adjustment on the bottom for rebound or anything else.
    I did try the same stacks without the adjuster swap so it was same as stock and it didn't feel as good, swap the rebound check valve around and it made them better.
    rebound stack is slightly different (stiffer) with a bleed shim, stays up really high in the stroke now, blue oring is installed still.
    What I have might not suit everyone but I was looking for an alternative than spending big bucks with a tuner and are presently surprised with what I ended up with
    ray_ray, mike243 and reveille like this.
  6. Motosportz CH Sponsor
    I would never want a set of forks (or shock) with no rebound adjusters. I find rebound adjustment the most important adjustment on a fork.
    Norman Foley likes this.
  7. Steve Kanya Husqvarna
  8. Norman Foley Husqvarna
    When I read his post, I thought he must ride only one type of terrain, to have no rebound adjustment....
  9. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Once I set mine I don't move it... I ride everything every ride....
  10. ajaxauto Husqvarna
    Same here once some one who is smarter then me sets up my suspention I install it and ride. Never have I had to touch it. When you race the Nationals we go everywhere and still no adjustment needed .
    ray_ray likes this.
  11. bowser Husqvarna
    FE350
    don't get me wrong I wish I still had the option to adjust rebound but at the moment they are working well for the riding i'm doing.
    many guys don't even adjust sag let alone play with the clicker voodoo magic
    ptkatoomer likes this.
  12. Motosportz CH Sponsor
    both bad practices IMHO. Chassis setup and suspension fine tuning is some of the best performance gains there are.
  13. racemx904 Husqvarna
    owenton, ky
    Once it's set it don't change day to day
  14. Motosportz CH Sponsor
    For me I like to adjust it for where I ride. Sometimes it is tight woods, some times it is whooped out dez, some times it is DS, maybe one day it is MX, usually fine tuning for rock gardens is normal... for me. All like different setups. Also riding in mud can add 20 pounds to your bike, some compensation is nice. Even fuel levels can change the weight on the forks as much as 20 pounds. I've even needed to change rebound for heavier tubes and tires. In the summer I ride much faster (dry conditions) and weigh a lot less (gear and mud). A few clicks either way can make a huge difference. They have clickers for a reason. Every bike I have ever had that had a adjustment missing I was always frustrated with as I knew it could be better with a few clicks one way or another. The other day going two clicks stiffer rebound for riding through a lot of loose rock made a huge difference. I personally would never give it up. I even change tire pressures for where I ride.
    Chums likes this.
  15. racemx904 Husqvarna
    owenton, ky
    Most people are not very good at making changes... a lot of people make changes thinking they are doing something good and they would ride just as fast or good leaving it the same....
  16. Motosportz CH Sponsor
    Yeah I ride with some of those people and watch them struggle and get kicked all over the trail with crap setups.
  17. Lincolnlock Husqvarna
    Mount Vernon, WA
    I'll just be happy to get the forks back. They've had the forks longer than I've been able to ride the bike. I'm forced to ride my wife's 200xc Gasser for tomorrow's ride. Already took the stupid rekluse out of it so I can ride it. I'm starting to regret my decision to get rid of the 2012.
    :I obviously need a tissue: :(
  18. bowser Husqvarna
    FE350
    who has the forks and what are the issues?
  19. Kawagumby Husqvarna
    2009 TE310, 2014 TE250
    WR250R, KDX220, 1987KDX200
    When a person gets old like me, being crafty about setup is the great equalizer on the trail. I like it when my riding companions are bouncing all over the place...LOL....and yes I want my rebound adjustment too!
  20. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    I agree. Some guys like to tinker though. I prefer to change my riding style slightly to use the same set up, for all riding.
