Awesome!I love aircooled 2 stokes too but I am now on an new 2011 WR150 and am loving it. I got it for the ease of maintainace and handling. BUT, I love how this motor runs too.
I find that the comments on the Maico are at the margin an embellishment. The motors had real grunt, however their brakes and suspension were pretty poor by todays standard.
Totally agree. If the suspension on that Maico is better there is something terribly wrong with the Suzuki he was riding. I like old bikes but lets get serious. also the shot of the new YZ450F with that caption that it needs taken apart every 10 hours is goofy. I have seen 99 YZF400 with a million miles and still stock and never opened up. One of the most reliable modern 4st's going. This article is slanted hard towards 2 strokes. IMHO it would be tough to say straight up if 2 or 4 strokes are better but i think the current 4st have really proven themselves to be GREAT MX/SX bikes. The power and traction as key to clearing some of todays stuff. Peopel are free to race a 250 2 stroke and choose not to and if try are not competitive. At local races where you can race anything 90% of the field is 4 st. It is an interesting conversation. BTW i would say it was Doug Henry / Yamaha that killed 2 strokes not Honda, they were late to the party.
Also, for the average off-road guy, the overall operation & maintenance costs are now pretty close between a competition 4t and and a roughly comparable 2T. It's not like it was in 2003 anymore. The 4ts are lasting longer and are now much cheaper to repair than they used to be. I did a cost comparison on our clubs website a year or two ago & covered all the bases as best I could.
It's pretty much 'ride what you like' nowadays. The '4ts are way too expensive' arguments don't have near as much validity anymore, if at all.
Some of the issues raised by the article need to be brought into perspective a bit - noise is not a characteristic of a 4t or 2t but rather lack of a proper exhaust. I'm sorry, but a 2t on the pipe with an old style MX 'muffler' makes a racket that travels for about as far as a 4t with a similar exhaust. Both types of bikes are guilty - er rather the manufacturers and owners are guilty. Noise is still noise regardless of it's wave characteristic and it freaking annoys&irritates people.
For the typical woods/offroad rider(comparing 2t's vs. modern high perf. 4t's)-
The overall service life cost gap has narrowed somewhat with 2t's compared to the early days. Nowadays 4t top ends can often be done for $1000 or less, compared to $2000-2500 5 years ago.
They both use roughly similar amounts of oil over their lifetime. advantage -neither
4t's will use less gas- often 1/2 as much or less - advantage 4t (this will add up to $500+ over the life of the bike)
4t's will use fewer spark plugs - advantage 4t (I'm still on the original plug on my Husky TE250-almost 300 hours)
2t's are cheaper to rebuild(top end) ~$300 or less (piston & ring), but typically need to be done twice as often. Advantage - still 2t but the cost advantage is less than it was 5 years ago. Also, 4t top ends last longer nowadays than they did in the early days.
I believe 2t's typically need more frequent bottom end rebuilds(although I may be wrong...), if so - advantage 4t.
4t's have typically been heavier - advantage 2t(although that is rapidly diminishing ie. new Husky 250's)
Power delivery -advantage depends on what you prefer.
4t's tend not to get exhausts smashed up & replaced like 2t expansion chambers do. - advantage 4t.
I suspect 4t's, because they put power down better with less wheelspin would be easier on rear tires- possible advantage 4t...?
2t's are typically cheaper to purchase new - advantage 2t
I believe 2t's need mufflers repacked more often than 4t(based on my personal experience). If this applies across the board - advantage 4t.
Just some thoughts....
I run reg to med grade pump gas in my TE and TXC without issue; about 430hrs between the 2 bikes so far. Maybe some high comp 4ts need race gas, but not all........A 12:1 4t needs race fuel or at least octane boost which offsets the cost of me adding mix oil to pump gas on my 2t so that's a wash.
Here is what is not a wash: There is over $1000.00+ worth of parts on the top end of a 4t that don't exist on my 2t. From my past experience building high compression drag race engines I know that the valve train is the weak link and the most costly of all the moving parts and when something goes it usually takes all of it out with it.
