530 big bore kit installed!
Discussion in '4 Stroke' started by wilmar13, Aug 16, 2010.
  1. MXRider Husqvarna
    Virginia
    None
    2009 Yamaha YZ250F
    Well if a 510 (501cc) gets a 530 kit (532cc) then I would think a 450 (449cc) would be 480cc after the cylinder got milled. I have to admit I am tempted to do this when I go for a rebuild.
  2. J.R. Husqvarna
    Northern Utah
    450 Supermoto! and a BUNCH 'O parts
    Juicehall is thinkin of doin it, and so is Ash from Smj
  3. slidnrin Husqvarna
    Snack land
    I think i may have to get this mod done as well. Id also like to know any of the specs from the RR cams compared to the smr cams. Anyone know what the difference in lift and duration is between the two?
  4. J.R. Husqvarna
    Northern Utah
    I dont know the specs or technical side of cams, But I'd be interested to know.
  5. Brand-o Husqvarna
    Thread resurrection! :)
    Does anyone have any HP/torque comparisons between the stock 510 and the 530 kit? I've looked everywhere and can't find anything other than butt dyno results.
    Mik-3 likes this.
  6. Planepower Husqvarna
    Edmonton, Alberta
    2007 TC 250/ 450 6spd, 2007 SMR 530
    Ducat 1198S, SV1000, CBR125, DRZ125
    I have a baseline dyno readings from my 450 ----> 530
    HP is up by 5hp, and torque was up by a whole whopping 7ftlbs. The 2 dyno runs were about 4 months apart, and temp & humidity differed.
    Where i noticed a difference was the FLAT torque. Power came on at around 4000rpm, and carried that to 8500. the 450 torque rise started at 6000.
    Thats why people notice it more on the butt dyno.
  7. Romanousky Husqvarna
    2008 SMR 510
    '05 DRZ400SM, '03 CRF450R, '81 XS650
    I've got a question for you all and thought I would try to bring this thread back to life...
    I've blown my smr 510 engine and am forced to replace the following regardless of which direction I go:
    Cylinder (beyond repair)
    Valves, springs, timing chain, valve guides, etc...
    Intake camshaft must be replaced
    Con rod
    Piston
    ...and a few other things
    Here is the question:
    I want to do the 530 kit to gain some bottom end. Should I do the RR version? As far as I know this is just the 530 kit with stiffer intake springs, different spring caps, and RR intake cam. I don't really want to do ant porting if I don't have to. I don't want to lose any reliability. Is the RR cam going to work the engine much harder?
    Lastly, this bike is used primarily for street. Maybe a Few races in the summer but not much. I am very unfamiliar with Husky's so don't be shy to point out the obvious.
    Thanks
  8. J.R. Husqvarna
    Northern Utah
    Romanousky, I sent you a PM on SMJ about this just now but it will be good to add here as well.
    THe RR cam will be more harsh on the top end. According to Paul at GP cycles, it tends to wear the valve cups out. (The little retainers/keepers atop the spring that the clips sit inside of.)
  9. Mik-3 Husqvarna
    Finland
    Husvarna SM510R 2010
    I was very interested in, i finally got that 530cc kit.
    What else than the head porting, what about the injector, cam shafts, valves or just the cylinder + exhaust pipes, pvc V???
    Use to be mostly on the street.
  10. Mik-3 Husqvarna
    Finland
    And here is Results.
    Yesterday I went to dyno.
    -else stock Leovince front / y-pipe akrapovic + + pc = V 54.7hv 8083rpm/52.9Nm @ @ 6292rpm.
    -530cckit + arrow-style piping pc + V + Killer = 54.4hv 7631rpm/53.8Nm @ @ 6208rpm, Killer break power top rpm drastically.
    -Same as above, but not killer, no adjustment 56.3hv = @ @ 6117rpm 8008rpm/56.9Nm, very lean
    So did not come power much to me, if you compare €+Hp is expensive, but the last dyno pull reading missing, where the bike was adjusted.
    Power readings are on the engine.
  11. dzhanis Husqvarna
    tc 510 '06
    xr600
    can someone tell me 510 rod length- from pin to pin center ? hysky 06' . I want to make sure I order the right connecting rod
  12. motosportz mike CH Sponsor
    Washington state
    I measured the holes in a rod (with a caliper) and the holes top to bottom are 138.3mm and the holes bottom to top are 81.3mm the center to center should be in the middle. The rod kit I measured is a new OEM one I have left over from my 510 I sold. I would take a bit of a loss on it since I sold my bike. Motosportz Mike.
    dzhanis likes this.
  13. Rodrigo Schmidt Husqvarna
    SM 510R
    I'm rebuilding the engine of my 510 Sm, I was thinking about using a 530 kit, would it take a connecting rod special or original enough for the new power?
  14. Mik-3 Husqvarna
    Finland
    If you dont want to use special connecting rod, original enough.....I have bone stock engine, whit 530cc kit, no problem....
