250-500cc 6 speed
Discussion in '2 Stroke' started by Chisler, Jun 25, 2020.
  1. Chisler Husqvarna
    British Columbia, Chilliwack River Valley
    2010 WR 300 Husqvarna
    It showed up .... but no time to play ... gotta go to work ..... : / AA4E5F8F-B2AB-418A-933A-8733A6C91C61.jpeg
  2. Chisler Husqvarna
    A2037DCD-1437-4590-BCDD-070A75975951.png Showed up just now .... spins freely ... guess that’s a good sign ... Lol
  3. Chisler Husqvarna
  4. Chisler Husqvarna
  5. Chisler Husqvarna
  6. Chisler Husqvarna
  7. Chisler Husqvarna
    Similar but different ....
  8. wallybean Mini-Sponsor
    Montana
    You need to use all the shifter parts from the WXE with the six speed. You should be able to use your old shifter pedal. Looks like you have all the parts in the box.
    Chisler likes this.
  9. Chisler Husqvarna
    Thanks Walt .... I haven’t split the cases yet on the one that showed but I did get it shifting on the bench ... goes thru all the gears nicely ... : )
    wallybean likes this.
  10. Chisler Husqvarna
    I don’t have this in the box of parts .... 6 speed arm ... the fun begins ... Lol
    Arm .. spring and fastener
  11. Chisler Husqvarna
    What I found in the box of parts ... 972E8F65-F32D-4AA3-8DFE-850DF09A4999.jpeg
  12. Chisler Husqvarna
    Guess it should look like this .... 39B2C3CC-CBA5-4946-9BE3-8FE9952287F8.png
  13. Chisler Husqvarna
    This is what I did to check out the gear shifting operation by hand .... Lol
  14. Chisler Husqvarna
  15. Chisler Husqvarna
    You were right Walt ... parts were in the box
  16. Chisler Husqvarna
    6A9904EF-E23E-442D-BC24-E47E7E2AC3C7.jpeg shift roller correctly attached ... and resting against the star selector wheel.
  17. Chisler Husqvarna
    And now with the shift shaft installed .... and it shifts thru all 6speeds on the bench .... : ) 31E90756-E3EF-4971-B259-EC58EA3F3894.png
  18. Chisler Husqvarna
    And for comparison , what the Wr 5speed shift mechanism looks like .... quite the difference ... 7A90DC16-0459-493B-98D7-06B121CBEED2.png
  19. Chisler Husqvarna
    So I’m happy with the shifting with the shift lever installed .... now it’s time for some heart surgery ... gonna split it apart and take a lot pics ... and number them shift forks .... and watch them needles on the one gear ... hopefully they stay in place ... : ) D3655297-79A5-447B-8303-C0E4FAB3DB1A.png
    Hurky, wallybean and 2premo like this.
  20. rancher1 Husqvarna
    WA
    #23 is a spacer, you will definitely need the oring or it wlll leak oil.
    Chisler likes this.
