My logic says the big end has to cope with the power the engine makes not the cubic capacity. If a 450 is making 60hp, then the standard 630 big end should be able to cope right up to 60hp.THe problem is the big end is too small. Its the size of a 450 and this is a 600. The big end of a Raptor 650 is 5mm bigger..
How do you know what is noisy for a single anyway? They always sound like they are about to self destruct at any second. Also I really question the economy of an engine rebuild when you could get another second hand bike for a couple thou.
Well Flynn . Have you looked at prices of those bikes used. Its still worth at least 4000 on the used market. My rebuilt is not going to cost me more than 2500 thanks all in with shipping modified bottom end with better rod and forged plus prête Head . So I'm still way ahead of the game and the engine is now billet proof.
Ive been using Motul 5000 10w40 semi synth and have passed 10000 miles, maybe im just lucky.Well still figuring things out but Im pretty sure to have finally found a solution with the help of HTM in Italy. Will be going with there 630 piston and a Carrillo rod with an off-set grind performed to the crank to make it all work. They also said it a poor design with too short of a rod putting a lot of pressure on that poor bearing. They also pointed out that these engines are really sensitive to oil and that I should have been running the factory recommended 10w50 or some 10w60 not the 10w40 I was using. OH well you pay to learn.![]()
I just cant buy into that.They're just saying the ratio of stroke to rod length is high, meaning the rod gets loaded at a steeper angle where mechanical advantage means higher bearing loads. .
I don't think I've heard of any other big end failures, but never the less I did have Zip Ty do their crankshaft mod on my 630 to provide better oiling. I've been running 0W-40 in my 310, but heavier 20W-50 Golden Spectro full synthetic in the 630 because of the additives. Per George! All OK so far.
