It is an XR clevis. I think it set me back about $7.Thanks for posting the photos.. I still need to fix mine. Would it be possible to add some type of shim material to the brake arm (some JB Weld?) so that the stop would be functional?
Is that the XR650 clevis?
I think that's a MUCH better answer than JB weld! Nice call!If you look close at the photo's I posted above, I put a sleeve around the pedal stop to increase the diameter. Still makes for an adjustable stop just a larger diameter.
Haha, you're tall like me aren't you...
I maxed out the adjustment on mine and it's about enough, but it's still a bit difficult to cover the brake wearing boots on one wheel while still sitting in my normal position...
Does your rear tire turn freely without any pressure on the brake peddle?
Lift up the back end and spin the rear tire while off the ground.
