FE/FC 701 Enduro It's official!
Discussion in '4st' started by reveille, Oct 27, 2015.
  1. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    ^ This is probably because the owners know the threads on the WP shock body are soft as butter and they are afraid to put a tool on them and have the treads fall apart and ruin their shock. I have seen this first hand. Search 690 forums and you will see what I am talking about.
  2. RDTCU Husqvarna
    '11 630SMS
    Well the lock rings on the 701 are plastic... :confused:
  3. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    ^ I bet they are plastic as that is one c**t hair softer then the shock body threads. :doh:
    duggoey likes this.
  4. r6jon Husqvarna
    West Linn, OR
    16 701 Enduro on 17's :)
    a FE450 soon
    Why would you remove the shock to set the sag mark?
  5. RDTCU Husqvarna
    '11 630SMS
    It's pretty tight in there and you can't get to the load and lock rings with a spanner tool. The "easy way" in such a case is a long flat-head screwdriver and a mallet. But on the 701, the lock rings are plastic and you don't want to tear them up by hammering on them...
    You should be able to get to it by flipping up the tank, but I haven't seen that done personally.
  6. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    A soft piece of pine works good then tap with a hammer. On my 501, it's a pain and i use the pine slat but my 300 xc w is easy with a enduro engineering spanner. I use a 3/4"×3/4" × 18" long pine slat. It's sacrificial and won't damage the plastic lock rings. Having the rear wheel off the ground helps too.
  7. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    On the 690 the seat comes off with the key. You can then pivot the tank/subframe upwards by removing the two rear "subframe" bolts. I attached tie downs from the tank to the ceiling beams and just moved the bike backwards which worked perfectly. I can't remember of you can get to the shock easier, but it's so easy to do its worthwhile. I had my suspension done by the shop.
  8. stego Husqvarna
    Hi, I'm thinking to change my Strada with 701 or 690. Do you know somebody if it is possible to replace Husky instrument panel with one from KTM. It seem to me that they did everything bit better with Husky except this. I'd like to know when I'm going run out of fuel.
