73' CR400 Restoration...
Discussion in 'Vintage Restoration Projects' started by retro rocket, Apr 16, 2010.
  1. retro rocket Husqvarna
    This is my second gas tank - its going to be my race tank as its got a few dings in it.... in these shots I have just taken it out of the blast cabinet.
    The chrome on the sides is Ok - one small bubble and a shallow dent. I masked it off with clear packing tape that seems to hold up well to 100psi of aluminum oxide!
    Any suggestions on color scheme...? (the other tank is in original maroon so this one can be just about any color)
    Happy turkey day to all.
  2. mike328 Husqvarna
    colorado
    Tom, that 'race tank' looks like its in great shape...
    just my 2c....but I saw a guy paint a car engine hood and he had 'water spots' in painted onto it...interesting effect.. get your base color, spray water droplets, then airbrush white paint and let the water evaporate...
    I'll look for the link..
    I say go wild maybe maroon top, and purple sides?....LOL
    I post the above but actually I'm conservative and would probably go with the vintage husky red or orange..
  3. jagrdog68 Husqvarna
    Sammamish, WA
    72' CR400, 2016 TE300.
    80' CR250, 80' CR480, 75' 400 Maico
    I would be real interested in your latest chain slipper in Stainless. I figure you can apply teflon sheet to it for more protection.
    Let me know.
  4. retro rocket Husqvarna
    I agree with you regarding the teflon cover for my stainless chain slipper - A good idea I suspect.
    I can do more if you want one.
    Once this bike is running we will see if it serves any purpose!
  5. retro rocket Husqvarna
    FINISHED !
    Here are some pictures ...
    As bought just over a year ago
    Today ....
    Runs very well and starts far easier than I was expecting. Absolutely everything has been done I think (hope) that I have left no stone unturned to get this bike right.
    Here are some of the mile stones in pictures that I covered in the last few months...
    I chose to send the engine out to John Leferve - I refinished the cases before hand. The barrel was bored locally to a 1st over with an original mahle.
    I also assembled a complete tranny with the least visable wear. I upgraded the final drive shaft to accept the later splined sprokets - rather than the conical variety.
    The motoplat was rebuilt by Vance Smith and seems to work just fine.
    The cases were from a CR250 - they took a bit of machining and have the added benefit of an ignition side bearing oil cooling channel.
    I have chosen to make a chain tensioner ... I am not 100% sure that it was necessary but I really enjoyed making it and I think I did a good job of it! - Once I get a chance to spend some time out on the bike out on the track I will truly be able to gauge if it has had a positive effect... Husky could have done this but did'nt .... Any thoughts??
    Heres how it started... A skate board wheel amd some mild steel stock. The spring is from a 79' RM125/250/400 - still available.
  6. retro rocket Husqvarna
    This is after I turned down the end of the bush before tig welding it onto the arm ...
    _________________________________________________________________________________
    Here is my first trial fitment... I drilled the frame in order to pass the bolt all the way through to support both sides of the tensioner... There is a bolt on the back. DSCN0205.JPG
    Another veiw with a new red skate board wheel, these wheels seem ideal as they are tough and come with bearings ... DSCN0223.JPG
  7. retro rocket Husqvarna
    A couple of extra views of the tensioner. As viewed from under the bike looking up. DSCN0212.JPG
    I have not run the bike with the tensioner on yet so I am guessing I may have to play around with it a bit to get it dialed in but its not exactly brain surgery so I am in with a chance of making it work right.
    I may look at removing the rear chain guide or opening it up... any thoughts??
    Here are some more random images...
    DSCN0129.JPG _________________________________________________________________________________
    Below is making a custom throttle cable from racing bicycle gear cable (very slick and rigid) and the smoothest throttle cable I have ever used. (and cost $6 bucks to make)
  8. retro rocket Husqvarna
    Bicycle gear cable housing center - versus traditional throttle cable housing. View attachment 7918 P1070527.JPG Making the cable inner ....
  9. retro rocket Husqvarna
    And I did it all because this is what I want to do........CANT WAIT !!
    If any of you are doing any vintage racing here in the NY, NJ or CT area this summer please let me know.
    A special big thank you to all of you that said such great things as I skinned my knuckles, scratched my head, wondered if Id ever finish this bike!
    THANK YOU!
  10. Gord Husqvarna
    New England
    SHE'S GORGEOUS You have given me some ideas for my 73 WR. I'm getting close to the finish. You've done some beautiful work. I wish I had a small bench lathe. It's fun to make your own parts.
  11. mike328 Husqvarna
    colorado
    Tom....wow she looks GREAT!.. I like the mods you did!..
    Enjoy !!
    I need to apply some barrel ends on a set of cables, what did you use to solder them with.
    The reason I am asking is because I read somewhere to use silver solder...Comment?
  12. retro rocket Husqvarna
    Mike - thank you. You know what a labour of love these things are ...
    I will email you all the info I have collected on making cables as soon as I get a chance. Its actually quite a fiddle but the end results are better than the stuff you can buy (in my opinion)
  13. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Beautiful! Can we see a shot from the left side... want to see how that custom exhaust you modded came out. I see you turned the Falcon's the other way around (shaft end down). Nice.
  14. retro rocket Husqvarna
    Here you go .... Its pretty much standard except you can remove the heat sheild with two M6 bolts. DSCN0379.JPG
  15. retro rocket Husqvarna
    wrx and 454x like this.
  16. mike328 Husqvarna
    colorado
    BEAUTY!!!...
  17. mike328 Husqvarna
    colorado
    how was the work ... of John ?... I bet started right up?..
  18. retro rocket Husqvarna
    John has done a good job, the bike started third or forth kick... there were some minor issues with the clutch that I got sorted pretty quick.
    The Bing is performing well (fully rebuilt) - No complaints so far.
    Next week I am putting it on the track. So far the only run time has been on the road.... It served well to get the carb and clutch dialed in.
    I love the HUGE great big wall of power... A friend of mine rode it and said it was quicker off the line than his vintage Ducati 500. (and probably better off road too - lol)
    Overall I am very pleased with the bike. Im intrested in the possible upgrading of the front brake hub - Early 80's double cam unit maybe. I would also like to fit some pro fab tripple trees or the ones John or Husky junk sell.
  19. Picklito Husqvarna
    Washington
    Thanks! It's amazing. Please tell more about how it runs and what the power's like!!
  20. halffast Husqvarna
    East Sparta , Ohio
    Nice resto ! I went with a set of Husky Junk triples and love them . I noticed the rear brake pedal is riding high and this is a common problem on the these old bikes . The tab at the bottom of the pedal that is supposed to limit its upward travel is too wimpy ; it wears and bends allowing the pedal to move too far upward . That position makes you take your foot off the peg and stomp down on the pedal with little" feel " for the brake which can result in locking it up and stalling the engine . I had this problem on my Mag . Tried bending the tab , beefing it up , etc. all to no avail . I ended up fabbing a bracket and welding it to the back side of the pedal . The bracket has a threaded hole for a bolt that goes up against the back cradle portion of the frame . This bolt creats an adjustable pedal stop . Use a nut on the bolt threads to lock it into position . You may want to weld a piece of metal on the frame for the bolt to contact so it doesn't wear into the frame . This setup works well and is out of the way . Sorry , no picture but I hope I have described the adjustable stop well enough that an excellent fabricator such as yourself can easily make one .
