82 250 CR OUT OF IDEAS??
Discussion in 'Vintage/Left Kickers' started by demmick, Sep 15, 2015.
  1. PawPaw Husqvarna
    2013 TC 449
    Honda Crf450R + old CB750
    Have you reset your float height?
    Is the needle for the float sealing off completely?
    Paw Paw
  2. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    If you passed a leakdown test with the piston below top of transfer ports to allow pressure to fill the crank well to test your crank seals if your piston and ring do not leak, you should not have a seal issue on either end of the crank
  3. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    Here is the jetting I use on my 83 250XC. 38mm carb, 32;1 fuel mix, 330 main, 35 pilot, Q-5 needle jet, 6DH20 needle #2 clip position, 2.0 slide. This is at a corrected altitude of 3758ft. At a corrected altitude of 1340ft I run a 360 main jet and make an adjustment on the idle mixture screw slightly richer. Motor runs crisp and clean all through the RPM range and spark plug stays a nice tan color on the porcelain and light black soot on the outer edges of the base. Not saying this is the jetting you need but just to give you an idea. OH yea, have you pressure tested your carbs float valve?
    Marty
  4. demmick Husqvarna
    pennsylvaina,usa
    1980 390 wr,1980 390cr 1982 250cr.
    2011 ktm 300xcw,2012 bmw 800gs
    yes i agree. i put the air in and gauge on the intake side so piston location should'nt matter. going to change them anyway have them on hand and motor is already stripped down. going to replace the float needle valve and seat when i get it back together recheck float height and start the jetting process.
  5. demmick Husqvarna
    pennsylvaina,usa
    i'm at around 1300ft do you know what stock jetting was? must be pretty close to my 82cr.
  6. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    this for the 83 xc
    your jetting:
    410 main
    R4 needle jet
    45 idling
    6dh20 needle
    stock clip is 4th down i think i was at 3rd
    I can see blubbering and smoking written all over this.....
  7. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    I have a 87 Wr 400 here [ not mine ]that sounds rich [ blubbery but no extra smoke ] at full throttle and nothing I have done has changed it.
    Swapped standard ignitions/carbs. [ ignition and carb off one that runs fine ]
    Ran with no air filter.
    Cleaned out exhaust.
    Nothing changes it.
    Funny thing is that the guy that sold it went thru the same process.
    One day I'll get back to it if I don't die first.
