83 250WR fork and washer question
Discussion in 'Vintage/Left Kickers' started by AbnMike, May 20, 2018.
  1. AbnMike Husqvarna
    Morgantown, WV
    vintage 250 WR
    I didn't want to leave them out, just did. That's why I was asking where they went. I've never worked on a bike that had them before so when I put my Wiseco piston in after having the cylinder bored I didn't include them. After putting everything back together they were left over.
    So now I'll pull the cylinder again and install them correctly.
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    those bits in your forks are a custom addition. a previous PO felt t he need for some extra preload to reduce the plushness factor or account for extra baggage:thinking:
  3. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    The wiseCo pis ton might not even need them
    DaveM and 2premo like this.
  4. AbnMike Husqvarna
    Morgantown, WV
    vintage 250 WR
    Thanks for all the help. This is my first Husqvarna so learning the quirks. The two spacers definitely fit with the Wiseco piston so they're back in place and a lesson learned: Stop telling myself I'll "remember" things because I won't.
    I put the aluminum spacer back on top of the forks since the last time I rode it it seemed fine to me. I could probably afford to drop a couple pounds around my belly.
    Now to order the fork studs and hopefully get this thing back together.
  5. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Take a long look at your threads that embed into ypur forks legs. See if you see what I see. Check the style/makeup is a hint.
  6. AbnMike Husqvarna
    Morgantown, WV
    vintage 250 WR
    I don’t get it?
    I asked if they could be replaced and was told yes they screw in.
    I don’t see what you see?
  7. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    You may need to heat up the fork leg to remove and replace the stud. Just like cylinder studs. Bake, not torch is better.
  8. Bigbill Husqvarna
    '83 250wr
    0 right now
    When I was younger I’d laugh at some who used string and labels on all the parts they disassembled. Now I’m old and getting feeble I realize if I take something apart I better put it back together or label the parts. It’s great being old.....
  9. Joe Chod Husqvarna
    upstate NY
    been away and just checking CH now.....
    ....knew they were the piston pin spacers right from the wear marks and size/thickness. Damn Airborne....stay alert/stay alive
  10. Joe Chod Husqvarna
    upstate NY
    BTW those are getting tougher to find if you are missing them too
  11. AbnMike Husqvarna
    Morgantown, WV
    vintage 250 WR
    Well to be fair in my first post I did mistakenly say I didn't have the motor apart and only clarified I had the top end off when Marty asked....
    I'm about to tackle these fork stud things this week. Any advice to go about it without mangling and ruining them? The ends are already screwed up as you guys can see, so I'm hoping to be able to somehow coax two nuts on there and try to remove them with double nuts.
    I am going to try a few heat cycles, too, maybe two or three and let it rest and hit it with PB Blaster then a couple more the next day. I can be somewhat patient with this....I would prefer not disassembling the forks and do it with them in place on the bike.
    DaveM likes this.
  12. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    tack a bead of weld onto the nut when you have it on the stud enough so you super heat the stud and fix the removal tool to the stud in one go.let it cool before hitting the spanners. the last thing you want is to shear it off flush:eek:
    DaveM likes this.
  13. AbnMike Husqvarna
    Morgantown, WV
    vintage 250 WR
    Much ado about nothing...
    The studs backed right on out.
  14. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    nice work
  15. hva-factory CH Sponsor
    uk
    Husqvarna 510TE , 300WR Etc...
