83 430 Rider Project
Discussion in 'Vintage Restoration Projects' started by Chayzed Pilot, Sep 29, 2013.
  1. Chayzed Pilot Husqvarna
    So Cal
    2004 TC450,1978 390CR,1983 430 Wr
    A gaggle of them
    Your very welcome. Whilst I have been doing other stuff and working on the project (seems like I have too many projects) I didn't like the bar mounts and stripped them and painted them black with a satin clear coat on them. I like this look better than the plain blasted ones.
    I got the footpegs mounted yesterday. I had to machine the bolts a little shorter as there was too much thread showing. I forgot how hard grade 8 is till I cut in on the lathe.
    Today's adventure may be getting the carb out of the pinesol concoction and cleaning it up. I am pretty sure I will have to soda blast the body and bowl.
    More to come.
    390Dave and dartyppyt like this.
  2. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    I didn't get around to working on the carb today so I built a shock tree out of an old coat rack that broke. I try to recycle as much as I can. It will work perfect for letting paint dry. I got 2 more sets in the mail today for Husky's.
    jimspac, Motosportz, suprize and 2 others like this.
  3. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    I have accomplished some more stuff since Saturday. I totally messed up my blasting air compressor pressure regulator switch. I won't even go into that.
    I got the carb out of the pinesol concoction and soda blasted it, so I will start putting that together this week.
    Received my new to me tank from Darin on Monday. I had to strip the gas cap as it was painted white.............who would have guessed. I then polished it out with some Mothers metal polish. It all looks pretty good.
    More to come in a few.
    Rossik and Motosportz like this.
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Hey, looking good! Can't wait to see tank on your silver frame. Cap looks good.
    What is your pinesol concoction? How long do you let it soak? I have one kinda corroded some but not real bad. How was that one when you started with it? When you soda blast it, are you doing inside and out?
  5. Ron Husqvarna
    Azusa, CA
    That tank is purty!! Nice job Darin, what repairs? LOL
  6. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    You use pinesol with water. On the bottle it says for heavy grease removal 1 part pinesol to four parts water. I have tried it straight but IMO it works the best at 1:2 or 1:3. I let it soak a day to a day and a half and I agitate the bucket every few hours to swish it around. This carb was pretty bad to start with, it had paint and grime all over and inside it. It took some of the paint off and most of the dried up fuel in the bowl. Wash it off with water and see how it looks. I don't usually soda blast the passage ways in the carb as I don't know if it will plug up or not. I usually just use air pressure through the passage ways and blast the outside of the carbs and the parts.
  7. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    I made this small soda blaster out of Nalgene bottle and some plastic tubing. It works good for the little stuff I do. Cost me about $5.
  8. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    After figuring out the tank dampers in another thread I put the tank on to see how it fits and looks. I'm likin it.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Looks sharp! Thanx on pinesol info. Like the safari hat in background.
  10. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
  11. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Here is my two cents, cause I almost shot these on. I wanted to real bad and think this would go good on your 83.
    Make up a stencil using blue painters tape. Then take them to local graphic place to make up the tanks stripes.
    That h logo I placed should be good.
    But replicate the blue/yellow stripes in this attachment and stick them on tank. Use black and silver as the colors instead of blue/yellow.
    Then you can get some side plate ones done in the silver/black/engine size in red.
    Your fork legs would look good black with husqvarna highlighted in red.
    Look good with black rims.
    That would be a bad arse bike!
    http://www.vintagehusky.com/products/decals/d0009.htm
    Motosportz likes this.
  12. Wildebeest90210 Husqvarna
    Gloucestershire.
    For my two penneth worth. Keep it simple then maybe backtrack to shiny bits. I like the tank as it is, I think the '83 is THE best looking Husky and am looking forward to seeing this one. Liking the black rims suggestion too !
  13. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    I like the looks of this bike I found on Vistuers thread.
    Barry Ranson likes this.
  14. Wildebeest90210 Husqvarna
    Gloucestershire.
    Hmmmm Not so understated :rolleyes:
    Roon and Barry Ranson like this.
  15. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I definitely like it better than the milk truck theme.
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I agree, both of those bikes look cool. Wildbeest, I told you this before! You did a great job, you got talent!
    The other red one looks like an 82 left over going on 83 factory bike.
    Mr Pilot, your bike is looking great, anyway it ends up will look good.
  17. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    I finished up Ron's Curnutts so now I'm bored so here are a couple of my other Huskys.
    This one is in one of my sheds, I may do it next.
    This one I may go ride tomorrow since I am a non-essential gubment employee.
    Motosportz and 454x like this.
  18. Chayzed Pilot Husqvarna
    So Cal
    A gaggle of them
    I worked on the bike a little last night and cleaned up the coil/CDI box. Getting all the paint off stuff has been a chore. I hooked up the three wires that I knew belonged with each other. The rest of the wiring harness is a mess. I only plan on riding this around in the desert so I will not be using the lights anyway. Here is the question for you experts in wiring. That is my weak point, and besides I haven't looked around for a diagram anyway. I am going to assume the non plugged in wire that the arrow is pointing to is the kill switch wire. Correct? There is no other place I can find in the harness that it would plug into. The bike has spark as it is wired now.
  19. Michel Dufayard Husqvarna
    France
    Orange wire is kill switch.
  20. Wildebeest90210 Husqvarna
    Gloucestershire.
    Can't wait for this bike to happen. But then, can't happen too soon :popcorn:
