83 XC500 dyno results
Discussion in 'Vintage/Left Kickers' started by White Husky, Oct 3, 2010.
  1. SA63 Husqvarna
    Glasshouse Qld, Australia
    84 510, 500 auto , 86 510
    I thought it was normal to fit a road tyre for a dyno run?
  2. s10an Husqvarna
    Norway
    That was a realy messy dyno chart. the curves should go in a steady line. As you can see it missfires real bad actually. Check all the tips in this thread. but i would guess ignition issue.
  3. hvaloz2 Husqvarna
    fareham
    hi fran k
    fareham is in the south of england....the uk husky importer in my era was only an hour away.... well not exactly miles ... but you know what i mean... on typical european sandy tracks with washboard bumpy straights... any husky would eat up the rest with its long wheelbase and superior suspension.
  4. subarumy98 Husqvarna
    Australia
    1983 500XC
    My jetting woes:
    XC500, just rebuilt with Woessner, rod and hone.
    Altitude = 2000m
    Pilot = 45
    Main = 410
    Slide = 2.5
    The initial impressions after start-up have settled into the following:
    bottom end is good
    lower-midrange is good
    upper-midrange is flat, burbles
    top-end burbles, starts to clear nicely, clears, but then falls on its face and goes petang, petang, petang till the fuel catches up.
    In a drag race with a Maico - I need to use the midrange, and shift early, if I try to rev out it takes so long to clear that its all over.
    Opinions, guesses and suggestions welcome:
  5. White Husky Husqvarna
    UK
    I'm no expert, (in fact I'm kind of ducking a bit as I write this becasue I'm overdue a follow up on this thread!) but revving-out should (to my simple mind) be all about
    • fuel into the carb
    • fuel and air into the cylinder
    • exhaust out.
    For fuel in - I'd check:
    • Tank cap vent not blocked?
    • Fuel filter not blocked?
    • Carb float height correct and fuel jet (or whatever it's called) working nicely
    For air in - I'd check:
    • Clean air filter
    • No air box lid? (They're for the 125 and 250s only)
    • No blocked jets (and it'd have to be the main jet at top revs)
    For exhaust out - I'd check
    • Spark arrestor not caked
    • Silencer packing fresh?
    • No big dings in header pipe?
    That's about as far as my comprehension goes. Internal engine seals baffle me but can apparently affect an engine's running.
    Sorry if you've already tried the above, and I'm sure I've missed something obvious. People always seem to say to swap the spark plug first as it's easy and can cause sporadic running for no obvious reason!
    Cheers
    Lucien
  6. husqyhamm Husqvarna
    South Africa
    Quite a few 83-86 500 2Ts and 4Ts
    84 R80 GS Dakar; Victory 106.
    @ Subaru, Ive never built 500 engines with anything but Mahle pistons.
    But from experience youre over jetted. 410 is fine for coastal on a cold day, 370/380 should do the job on Aircooled. Pilot=35. Needle tube AA5, needle 7DH3 with clip on 2nd from top groove.
    Maicos are quicker off the mark, but the Huskies ability to rev reels the Maicos in at end of 3rd gear.
  7. husqyhamm Husqvarna
    South Africa
    Oh yes, the simplest of lessons: On carb float bowl make sure the floats move freely all the way without catching against the gaskets. This has happened and youll never get it to sustain rpm. Make sure floatlevels are right and that needle seat is new.
  8. subarumy98 Husqvarna
    Australia
    1983 500XC
    @Humm, that's what I thought too ????
    Am I confusing over-fueling with running out of fuel ??
  9. hedhunter9 Husqvarna
    Indiana
    On a 2-stroke you would definately know the difference between over-fueling and running out of fuel..... (in-sufficiant fuel supply)
    Run out of fuel (and oil) and things get hot quick.
    Things melt quick.
    Things go BONK ! real quick.
    Bob Bean
    1986 ISDE Italy
    1987 ISDE Poland
    1989 ISDE Germany
  10. subarumy98 Husqvarna
    Australia
    1983 500XC
    @Hedhunter9
    I would agree normally,
    but it takes a while to clear through the top of the midrange. On top it hits a wall and almost dies.
    The float levels are almost to high, as on a slight slope the fuel comes out of the overflows..
    Need to go find some jets and a long stretch of quiet road.
    Compared to other bikes, indications are that the main is too big at 410.
  11. subarumy98 Husqvarna
    Australia
    1983 500XC
    My update:
    Altitude 2000m
    Pilot 50 (was 45)
    Main 390 (was 410)
    Needle 7DH3
    Emulsion AA5
    Findings:
    Starts easier.
    Runs a LOT better, but main still too big. On hard acceleration it will kill the spark ans start missing every now and again - so we are very close.
    Aside:
    The clutch setup is light enough to be considered for trails now. Teflon cable, extended arm and Barnet clutch pack with springs.
    Making some very good progress now.
    Any progress from you guys ?
    T
  12. subarumy98 Husqvarna
    Australia
    1983 500XC
    Final setup as follows:
    Altitude = 2000m
    Pilot = 45
    Main = 380
    Slide = 2.5
    YEAH BABY !
    Race day in 4 days time.
    Easy starter - no blubbering on test ride.
  13. subarumy98 Husqvarna
    Australia
    1983 500XC
    The followig was perfect:
    Altitude = 2000m
    Pilot = 45
    Main = 380
    Slide = 2.5
    Some changes instore:
    bars to combat arm-pump.
    Clutch with Barnett kit, long arm and teflon cable is perfect !
    Works style pegs - perfect.
    Gold Valves with 10w, 4 turns of yellow spring - perfect
    Shortened Husqvarna-parts Ohlins piggybacks - perfect
    All I could ask for was a longer track to stretch the Swedish honey's legs.
  14. subarumy98 Husqvarna
    Australia
    1983 500XC
    My race partner:
  15. White Husky Husqvarna
    UK
    Well it's been a while. Old Yella is finally running again. Turns out it was a loose wire behind the flywheel on the MZ-B ignition. It was shorting out with vibration at higher revs causing the sporadic running and haywire dyno chart from hell. Bike is now running smoothly so will be back on the dyno over the weekend hopefully. Will keep you posted.
    Cheers
    Lucien.
  16. subarumy98 Husqvarna
    Australia
    1983 500XC
    @WhiteHusky:
    Tell us soonest please.
    Post details of ease of starting, procedure to start etc
    Also final jetting and altitude
    T
  17. White Husky Husqvarna
    UK
    Here's a short Youtube clip of the old girl running. Hoping to get it fine-tuned this week.
    The seat isn't bolted down yet, hence the rear mudguard floating around in tune with that exhaust note 'music'.
    The bike has the Mikuni 38mm carb on it and that's a DEP enduro rear 'silencer'.
    Cheers
    Lucien
  18. subarumy98 Husqvarna
    Australia
    1983 500XC
    Now things are getting confusing...
    still been gettinbg that bong, bebong bong on the overrun, so dropped in a 460 main.
    The blonde honey started screaming like I don't know what. Took a long time to get through the mid-range, but once clear started revving out like I have never had before.
    Next step:
    Drop to a 450
    Clip on 2nd position
    Hang on tight
