'86 WR400 rebuild
Discussion in 'Vintage Restoration Projects' started by Eurofreak, Jan 8, 2017.
  1. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    if the power is disapponiting on your 400 something is wrong
    justintendo likes this.
  2. wrx Husqvarna
    845 newyork
    mine absolutely rocks
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    this...the 400/430 should wheelie at will in 3rd. it is a bit tractorish compared to a 250 perhaps but is no slug on top end, especially the 400. your jetting/timing is likely off.
  4. oldbikedude Husqvarna
    Honey Brook Pa.
    Suspension setup could effect the front lifting or not. Does the rear squat when you think it should be lifting the front?
  5. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    summats wrong, it should loft the wheel at will. ol mates was the same, super tractor but signed off way too early. he was impressed until he rode mine then he realised there was a major issue and the spanners were spinning. it was a restrictive muffler. he put a bigger bore silencer on it and away it went.
    oldbikedude likes this.
  6. Eurofreak Husqvarna
    Western NY
    1986 TE 510, 1982 CR250, 2008 WR250
    70's Triumph , Bultaco , Maico, etc
    I'll investigate once the weather warms. The timing could be off perhaps.
    My suspension has been stiffened in the rear
    Pretty sure this is a stock silencer-will investigate.
    Exhaust pipe has been cleaned, no rats fell out.
    Stock jetting anyone? Needle is in the middle position
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I think I ended up with a 430 main in the end, stock is 400 from memory
  8. Eric The Leg Husqvarna
    Currently Tacoma, WA
    1986 WR400, 1985 WRX400, 1979 WR250
    83 Kawasaki KZ 440
    I measured the opening at the back of my spark arrestor, it's about 35-36 mm wide opening, both 400's ('85, '86). The '85 stock silencer is all black like yours, but the spark arrestor was bigger/round, and has USFS Approved stamped into it. The '86 silencer is oblong and aluminum. Similar black round spark arrestor with the USFS Approved stamping. I took pictures, but my phone and my computer aren't cooperating this evening.
    Eurofreak likes this.
  9. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    For stock jetting, the parts manual has:
    6DH3 Needle
    Q6 Needle Jet
    400 main jet
    PJ 35 Pilot Jet
    2.0 air jet.
  10. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    My 85/400 only stands up rarely but man does it get fast quick , it also climbs hills a couple of gears higher than it should.
  11. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    I found that my 400 is sensitive to exhaust length, mine had a muffler that had been cut down to exit just behind the left side number plate, I tried a Up-Tite pipe and hated it, until I put the original 88 400WR muffler on and it is now a very different bike to ride, dial-a-wheelie!
    Tony.
  12. Eurofreak Husqvarna
    Western NY
    Thanks guys-I'll pull the carb apart today and check jetting. The silencer had the spark arrestor removed. Worth checking the dimensions.
    I haven't ridden it much other than to run it around the field a few times. Very muddy or very cold out right now.
  13. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    Guy at my local (former/old) husky shop would probably tell you to ride it a bit more before judging anything. Especially if it doesn't have that many recent miles, sometimes you've gotta' let things "settle in and loosen up" to revive the bike.
    Also, depending on the size of the field, on a cold day, my 400s might not start popping until the second or third time around. The one I've ridden most is jetted a touch rich too. Any more I don't even roll the throttle into high power band territory for the first few minutes anyway. Plenty of fun to be had in the low power band, and once the bike is ready for the serious riding, it'll pipe up and tell you.
  14. Eurofreak Husqvarna
    Western NY
    When I got it out it was in the 60's. It had enough time to get to temp.
    The weather here dropped into the 20's overnight with winds up to 60mph-bit of a change.
    main pilot and idle are stock. The needle was 1 slot low- I assume the stock position is the middle notch, so I raised it one notch. We'll try again in a bit. The silencer end measures 32mm
  15. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    32 vs 36 mm might not sound like much, but keep in mind that the area of a circle is calculated using the square of the radius. You've got 20% less exhaust capacity than the stock silencer/spark arrestor.
    ajcmbrown likes this.
  16. jonhicks Husqvarna
    1987 250 WRLC
    IT175J 1982 YAMAHA
  17. Eurofreak Husqvarna
    Western NY
    Thanks Jon. I found a stock replacement at the York swapmeet. The stock one has a larger black plastic back, same design lens.
  18. Eurofreak Husqvarna
    Western NY
    I'll look for markings on my silencer. If it was aluminum in 86 definitely have the wrong silencer.
  19. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    It was aluminum in 1986 and I have one from 1987 that aluminum but longer than the 1986 silencer. I have a Dirt Rider test that showed the 1986 400 Cross Country showed over 3 hp less than the 1985 400WRX. My WRX came with the last steel silencer and was missing it's end cap. DR used an Answer oval aluminum silencer/spark arrestor to get the missing power from the 1986 400 Cross Country. I was told the 1987 silencer is even more restrictive than the 1986. I am sure the 400 moving up to 430 lessened the effect somewhat
  20. Bigbill Husqvarna
    '83 250wr
    0 right now
    My '86/400 wrx had no lack in power. Just point it, wick it and hang on. The power was smooth and linear to the twistie.
