87 510 cam chain ?s
Discussion in 'Vintage/Left Kickers' started by 86 400 XC, Jul 16, 2016.
  1. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    The manual reefers to a max length as to when its time to replace.
    Not sure about the amount of rollers.
  2. Krudd Husqvarna
    Sweden
    89A 510TE, 89B 510TE
    '81 Yamaha XT500
    Ok thanks! I bought a 5 meter length SKF-chain and some master links. I'll measure up slightly less than 773,5mm.
  3. silverstreakNZ Husqvarna
    Christchurch nz
    82cr500,76gp360,90wr250,81 420AXC
    74 tm400 , 02 gasgas ec 300
    80 x the 9.525 pitch would give you 762 mm
  4. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Thanks, I found a photo of a 510 chain and it counts 82 rollers. Makes it 771,525mm. :)
    86 400 XC likes this.
  5. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    I do not like masterlinks on a cam chain. I cut to length and stake a solid link. A world of woe occurs when a cam chain master link fails
  6. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    I understand that view. But I'll rely on the info from an expert engine builder that it's ok; Claes Halvardsson of Halvards Motor.
    He's built engines for loads of pro's like Anders Eriksson, seven time world champ in enduro, and his own 414cc destroked 510 engine which he revs to 11500.
    Having said that I bet my 510 will spit the cam chain first time I take it past idle... :eek: ,touch wood...
  7. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    Claes is a great guy. I bought an NOS tank for my 87 510 from him a few years ago. Pure luck I stumbled on his website when googling for a tank! Tell him hi from down under!
  8. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Sure! I talked to him a couple of weeks back as he was putting a new rod kit in my 510 crank.
    He is going to retire in January at 75 yo, closing the bussiness down. But he'll still keep doing engine work he said.
  9. silverstreakNZ Husqvarna
    Christchurch nz
    Is there anywhere we can read more info on this 414 motor? Cheers
  10. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Don't think he has any info out on the www but I'll mail him and see if he can provide some.
  11. silverstreakNZ Husqvarna
    Christchurch nz
    Thanks . Yea nothing serious dont want to buy one or steal info . Just my owm curiosity
  12. Krudd Husqvarna
    Sweden
    '81 Yamaha XT500
    Here's the info I got from Claes re. the 414 cc. (It's an air cooled 510 to start with)
    "Crank is from a TE 410 1995
    Piston hi-comp. TE400, about 13:1
    Camshaft TC570
    Balanced crank
    Bench ran it up to 11500 rpm at which the inlet valves springs did not manage more and float. It makes 44 hp on the rear wheel.
    On the start grid I held it wide open throttle until valves floated and dumped the clutch when gate fell."
    silverstreakNZ likes this.
