MEGA_MAX
Ok ok, before you think I'm crazy hear me out. A company called Ecotron offers a universal EFI kit and small engine turbo. The EFI kit has been fitted to a DR650 before, so I think it would work with the TE610.
The company offers the turbo, along with an oil pump, oil cooler, and accessories such as flanges and bolts and whatnot, so my idea was to tap into the TE610 external oil line that runs from the bottom of the engine, then run the oil through the pump, then the turbo, then the cooler. If there's enough pressure maybe I could add an inline oil filter as well. Then the freshly filtered and cooled oil resumes the normal route and dumps onto the crankshaft.
By using the engines oil, I would be able to cool it, filter it, and increase the capacity, which would be a huge improvement over the current setup. Ideally this bike will be a daily driver and I've read how hard that can be on this engine.
I have many concerns about my plan, number one being whether or not I inhaled too many gasoline fumes yesterday disassembling the TE610.
Number is two the dual exhaust and it's turbo compatibility. Obviously adding two turbos is insane (as if adding one wasn't already ridiculous), so I would have to plumb it in where the two pipes combine, but I'm not sure if the single pipe diameter is small enough for the turbo.
Another concern is the compatibility of the plumbing in the oil pump with the engine and it's power consumption (not to mention the power consumption of the ECU).
The oil pump draws 1.3 Amps, the ECU draws 2-3 Amps I believe, which would be a draw on the stock stator. But if I use all LED lights then perhaps it is possible.
Something else I'm worried about is the size of the throttle bodies. Ecotron offers an EFI setup in 38 mm and 42 mm throttle body sizes, but I'm sure this could be remedied with an adapter.
If turbocharging the bike ends up being as ridiculous and unfeasible as I think it will be, then at the very least I would like to look into the possibility of adding the external oil cooler, pump and filter and possibly still the EFI system.
I've done some research, and while I can't find anything remotely like this, I have found quite a few threads talking about adding external oil pumps to the old pump-less huskies but no-one ever seems to go through with it. I'm willing to be a guinea pig, but I'm not going to attempt something that might be theoretically impossible. Here's some of the threads I found in the research:
http://www.thumpertalk.com/topic/729425-electric-oil-pump-on-a-husky/
http://www.thumpertalk.com/topic/291552-tc610-everyday-use-no-oil-pump/
http://supermotojunkie.com/showthread.php?89243-Adding-an-electric-oil-pump-to-an-older-Husky
And here's the Ecotron EFI kit and turbo:
http://www.ecotrons.com/products/400cc_to_800cc_engine_fuel_injection_kit/
http://www.ecotrons.com/products/small_engine_rhb31_vz21_turbocharger/
And here's the EFI kit on a DR650:
View: https://www.youtube.com/watch?v=n8tvQ42DIvY
I should mention that I also own a DR650, so worse case scenario is I could swap the EFI system over if I can't get it to work.
Lastly, this is all a lot of work, time, and money, all headed towards the primary objective of extending the life of the engine (which sounds counter intuitive since a turbo is being added, but is accomplished through oil capacity, circulation, filtration and cooling). One option that should always be considered is at what point would it be smarter to buy a newer Husky engine and adapt it to my bike? Not only would I get the newer technology but I could have an electric start too. However, I've had problems locating complete engines online.
