125-200cc aftermarket parts database
Discussion in '2 Stroke' started by Durangedgoat, Jul 29, 2020.
Do you want some more aftermarket parts options for the 125's?
Case saver 3 vote(s) 42.9%
shifter 4 vote(s) 57.1%
exhaust mounts 6 vote(s) 85.7%
engine mounts 2 vote(s) 28.6%
Multiple votes are allowed.
  1. JonR Husqvarna
    2013 Tc 250
  2. JonR Husqvarna
    2013 Tc 250
  3. JonR Husqvarna
    2013 Tc 250
    I need find stock silencer to go with pipe that what they said the setup was for the team when using that pipe outdoors and the procircuit pipe silencer was for supercross. And they used the 2CS pipe also . The guy I got the parts from was a good friend with team owner and he owns a husky dealer still . He has Travis Preston sx Huston winning bike and a Lamson 250 . He said was husky got sold to bmw the bike was cagiva hq office and he got it from there .
  4. JonR Husqvarna
    2013 Tc 250
    They Stamp FBF in cylinder but also a C by the intake right by the cast t . I wonder what that would be for. It says 01-38-Cr on head stock
  5. Sonnie Mee Husqvarna
    England
    Team Motorex Husqvarna CR125
    That’s awesome story I hope your friend keeps those bikes there rare real rare
  6. Sonnie Mee Husqvarna
    England
  7. JonR Husqvarna
    2013 Tc 250
    That’s so cool!! mine is written in the pipe slechten if you see it in picture
  8. Sonnie Mee Husqvarna
    England
    402BF835-E490-42F0-8F23-990B25E2DE7F.jpeg factory crank on left OEM on right
  9. Sonnie Mee Husqvarna
    England
    Yeah stamped in this was proper hand made cone pipe so they welded tag on
  10. JonR Husqvarna
    2013 Tc 250
    I’m going have to tear into the engine I guess and see what’s inside . What should I look out for ? All I know is the cylinder is stamped FBF and then the C stamp by intake
    Sonnie Mee likes this.
  11. Sonnie Mee Husqvarna
    England
    Have you got bash plate and water pump guard on yours 4217AC06-0A18-4D6D-BC76-DC7E9286D275.jpeg
  12. JonR Husqvarna
    2013 Tc 250
    No I don’t I just went on to garage and notice the cylinder head has 50 engraved into it also . Wonder what that means? Looks like Conroe just says on it by looking throu intake zo cagiva
  13. JonR Husqvarna
    2013 Tc 250
    Does 01-38-CR mean anything on headstock . I’m trying find out more infor about this bike also
  14. Sonnie Mee Husqvarna
    England
    So the cylinder should have porting work done on it around the exhaust valve main exit and two side exits, the bottom of the transfer ports will have been ground and and cleaned up and the transfer ports in the bore will have been tidied up
    may have had some work done to the exhaust valve itself re-shaped a little I ll take a few photos of the barrel I have that’s had the work done
    Factory clutch assembly I ll show you one tomorrow
    Factory crank as seen
    Factory head there were a couple of variations a deep dish head for sand like lommel and mudder races and a shallow dish for everything else with some extra drilling’s in to help cooling again I ll take some pictures of the ones I have
    That’s it I think
  15. Sonnie Mee Husqvarna
    England
    That’s interesting it could mean squish clearance it should be 1.25mm which is 0.050 inches
    The team here used to run 4mm base gasket and 1.25mm squish for best performance
  16. Sonnie Mee Husqvarna
    England
    Just means it’s a 2001 CR frame
  17. JonR Husqvarna
    2013 Tc 250
    Suppose to be 2002 when you bunch vin in says it is
  18. Sonnie Mee Husqvarna
    England
    So it has a frame number then with 2 before the V
  19. JonR Husqvarna
    2013 Tc 250
    Have you got the pictures I have sent? Just new to this site so just making sure your seeing pictures I uploaded
  20. Sonnie Mee Husqvarna
    England
    Yeah defo a 2002 CR250 the 2 in front of the V indicates model year the CR means The model and the 253 means the CC so CR250
