Aftermarket Wheels
Discussion in 'Super Moto' started by Super5onic88, Nov 26, 2013.
  1. 70RSMAT Husqvarna
    The TE has different forks to the smr though with different spacing I think
    Mik-3 likes this.
  2. Londin Husqvarna
    Denmark
    SMR 449 MY11
    Ducati 848 and Hypermotard 1100
    The te has the 48mm forks and therefor a very different setup aka no mods are needed.
  3. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    Any one ever check with Woodys Wheel Works?
    http://www.woodyswheelworks.com/
    Woody has been at the MC game for a long time and he and his crew have extensive knowledge in these areas. I'm pretty sure the KTM and BMW RAD hubs are things he designed and made then sold to them.........
  4. 70RSMAT Husqvarna
    So am I correct in thinking that when my alpinas get here for the smr I won't be able to run a beringer disc as they don't come with the 5mm offset on the disc that I need?
  5. 70RSMAT Husqvarna
  6. Londin Husqvarna
    Denmark
    SMR 449 MY11
    i dont know the Beringer setup but on my org caliber i had to get new wheel spacer, new disk spacer and an offset disk to get it to work!!
  7. 70RSMAT Husqvarna
    sounds a real pain, what disc did you go for?
  8. Caiman Senior Vice Procrastinator
    Australia
    SWM SM500R
    He had a motomaster flame rotor at one stage. Londin, have you thought about getting the spacer and rotor from a '09/10 SMR to see how they bolt up?
  9. Londin Husqvarna
    Denmark
    SMR 449 MY11
    No but I like the idea!
  10. Planepower Husqvarna
    Edmonton, Alberta
    2007 TC 250/ 450 6spd, 2007 SMR 530
    Ducat 1198S, SV1000, CBR125, DRZ125
    I had this issue a number of years back when I ordered rims and a set of hubs (RADD) the rear fit, but the front was a pain. I think when the aftermarket builds these things, they use the dirt models for info as the tech support was poor. I ended up having to locate an non current new replacement from a SM supplier to get the front to fit properly (can't remember whom anymore, but they have since shut down the business as I got one of the last remaining stock).
    Good luck.
  11. Super5onic88 Husqvarna
    Perth, Australia
    SMR 449
    RGV 250
    Beringer now do a 320mm ductile iron rotor so I ordered one of those to sort out the rotor issue. Just need a 10mm rotor spacer and the wheel should fit properly.
    Thinking of a bolt on spacer where the space bolts to the original rotor holes and then the spacer has its own threaded holes for the rotor to bolt to. That way the spacer isn't just sandwiched between the hub and the rotor like a giant washer.
  12. Londin Husqvarna
    Denmark
    SMR 449 MY11
    I'll try to take some photos over the weekend of my setup
