Troy F Collins
I didnt know that !!!rasputin;56443 said:the ktm exc200 is based on the 125cc engine.
the basic problem is that: it's not easy to optimize an engine for the power of a 125cc engine, and then attach a cylinder that has 50% more torque. basically you'd have to design the engine for the 200cc version in the beginning, but then you'd have a 125cc engine that is "over-engineered" and too heavy. and after all, 125cc is the main target, while 200cc is considered a "gadget".
r
Well KTM obviously built plenty of reserve in the 125 design...if it can accept a 6mm increase in stroke.....and still use the same crankcase....the husky case is parred to a minimum
the point I am trying to make is....if you look at most modern 2T bore and stroke dimensions....they are more often than not pretty close to square dimensions.....increases from bore size will only work to a certain point...strength is another kettle of fish altogether....
