Best Spark Plug 4 Terra: Show me your PLUGS
Discussion in 'TR650' started by mag00, Aug 6, 2014.
  1. Nick780 Husqvarna
    83 Suzuki GS400E
    Just switched from Brisks to Pulstars. When switching from stock to Brisk I really didn't notice much of a difference. After 5,000 km on the Brisks look at the white chalky-ness buildup: https://imgur.com/F3H1CYU,QbxiTR1,RMb0PuW
    Left plug is inside, right plug is outside.
    A few hundred kms on the Pulstars and there IS a noticeable difference. Definitely improved low end, and they cost me less than the Brisks so that's good too.
    mag00 and engineerk9 like this.
  2. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I did stock plugs, Iridium (Denso), Brisk, now Pulstars each change was an improvement
    mag00 likes this.
  3. LED Husqvarna
    Perth, WA
    TR 650 Terra
    Is there a need to have ECU reset or anything when changing to Pulstar plugs ? Disconnect battery ?
    Or just change them and ride away.
  4. drzcharlie Husqvarna
    No ECU reset necessary.
    engineerk9 likes this.
  5. Motosportz CH Sponsor
  6. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I disconnected my battery, as I do whenever I do any work on a bike's electrical work
    mag00 likes this.
  7. Shawn Johnson Husqvarna
    Seattle
    2013 Terra TR650
    2016 KTM 1190 R, 2017 KTM 690 Enduro
    I just installed the Pulstar plugs in my Terra and I can tell the engine runs smoother and has a littler better throttle response down low. Now I have no problem lifting the front wheel, before I had to word hard to get it off the ground. (Not that i'm doing wheelies all day.) :p
    engineerk9, drzcharlie and LED like this.
  8. drzcharlie Husqvarna
    I gave you a like just for your avatar!
    engineerk9 and tokor like this.
  9. DirtyOldMan Husqvarna
    Pleasant Hill MO
    13 Terra
    15 Beta XTrainer 04 250 RFS
    Just peeked into this thread to find out what replacement spark plugs to use.
    I think I'm going back with the stockers, I've got 10,000 miles on the originals.
    The bike still runs like it always has. A bit of that lean stumble right off idle sometimes
    but I've learned to just deal with it.
  10. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    Pulstars get a huge thumbs up from all who use them, me included
    mag00 likes this.
  11. DirtyOldMan Husqvarna
    Pleasant Hill MO
    13 Terra
    Do these pulstars require using the 16mm wrench like the brisk ones do?
    Where are you guys getting them?
    Thanks
  12. DirtyOldMan Husqvarna
    Pleasant Hill MO
    13 Terra
    Found the pulstars, could not find oem.
    So pulstars it is. Thanks
  13. Clete Husqvarna
    Tigard, OR
    '01 CR/WR 250, '13 650 Terra
    '06 Suzuki SV650 (gone)
    I ended getting the Brisks, and yet to install them. Would it be worth it to just go with the Pulstar's??
  14. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    go pulstar
  15. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I got mine from the Pulstar guy here in Aussie
  16. Next Strada Demolitionist
    Brevard, NC
    I'm pretty happy with the Brisk plugs. There is a noticeable sound/vibe difference at cold idle--little/no more chugging.
  17. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I was also impressed with the Brisk plugs, a noticeable improvement over the Iridium which replaced the OEMs
    The Pulstars are even better still
  18. Hansi Husqvarna
    State of Jefferson
    TR 650
    09 Versys
    What pulstars for the TR ? H2RT8 ?
  19. etotore Husqvarna
    Dumaguete Philippines
    Terra 650
    Honda XR 200
    PulStar je2rt8, two of them needed :) the (H2RT8 works for Honda XR-200) and they are 16 mm so same tool needed as for the Brisk.
    If you live in Europe or visiting Europe I ordered mine from http://pulstar.es/ got delivered promptly and much cheaper than transport from USA options.
  20. jawjo Husqvarna
    Cape Town
    TERRA 650
    Any leads for getting hold of Pulstars in Africa (Cape Town - South Africa to be exact)?
