TE/TC Best way to convert TE125 to a 200
Discussion in '2st' started by racemx904, Aug 10, 2015.
  1. Motosportz CH Sponsor
    sure looks like it or at least it has a KTM front fender :)
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    damnit if 150s where legal where you think this kid would finish:applause:
    lankydoug and Norman Foley like this.
  3. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
    i would strongly consider 150 kit on my 125.. but another alternative is to get better with clutch use :)
    i do agree that it's more difficult to ride fast.. I am faster on my beta 300 but 125 is sooo much fun and just not tiring to ride...
    now if only those forks would be as good as my KYB....
    Norman Foley likes this.
  4. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    Isnt the main reason to not get a 200 is that they are based on a 250 frame ?
    So engine swap makes some sense - or get an older 200 (pre 08? ) which had 125 frame and put an elec start kit on it .
    So you get the 125 feel with bigger motor and its easier - just old - and PDS .
    I am sure Norm has said that he doesn't like the feel of the 200 before and I kind of agree. ( I imagine they were 08- '11 vintage ?)
    Unless newer models are much different ie lighter
    I also didn't really like the power delivery of the 200 - preferred the 250 but that may also have changed .
  5. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    I HATE the smaller 125-200 chassis.... I like te full size chassis.... old 125 turns funny in tight stuff... and hate PDS.... I never got it right ever.... I had Bones from PC with our team out with us in Vegas and I finally gave up and just dealt with it....
  6. Norman Foley Husqvarna
    Last 200 I rode, was an '05 and I didn't like it much. Bulky and pipey. The 200 has changed a bunch over the years though. I haven't ridden a new 200 yet, but from have I read, the power delivery has changed.... less light switch like. '16 125EXC frame part number, is the same as the '16 200EXC (notation shows this frame dates from 2014). The US 200XC/W part number is different from EXC, but I assume that is because US model isn't street legal and lacks steering head lock. 250/300 frame number is completely different.
    Adding Estart is a pricey proposition, on top of a 200 conversion. Parts alone, are $1000 plus.... You need correct stator, ignition cover, all starter parts, complete wiring harrness and battery. Engine needs complete crank, piston, cylinder, head, PV assembly, PV timer, CDI, gasket, O rings and other hardware. These parts used, aren't that easy to find. Buying a complete bike and swapping engines starts to look cheap and easy by comparison.
  7. Motosportz CH Sponsor
    I believe the KTM200 uses the 125 frame.
  8. Motosportz CH Sponsor
    have you ridden an 09 and up italian husky? They are full sized and have great motors and can be made to 165 EZ. Also the best handling bikes I have ever rode.
  9. racemx904 Husqvarna
    owenton, ky
    I have had 3 of them and love them.... but I dont want to get stuck needing parts.... that may be a non issue nw but soon it will be.... If SWM or somebody makes that bike I would be first in line.....
    Plus I'm hoping to earn some contingency with Husky.... at least pay for my parts....
    Motosportz likes this.
  10. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    Norm you now have the direct line to Brad the engineer that has built up 2 late model OEM quality 200XC bikes....aint cheap but may be just the ticket, if it makes you happy get on with it, maybe we can get some media attention and your local dealer can kit them up or at leat have part list for self kitting.
  11. rockdancer Husqvarna
    Kelly - I read somewhere the older 200s used the 125 frame - and that changed at some point but I am not sure exactly - the 200 frame feels big compared to my wr125 and similar to a 250 exc to me
    not more spacious in the cockpit but feels like a bigger bike than the WR 125
  12. racemx904 Husqvarna
    owenton, ky
    I believe they just changed for 16'.... Husky is much taller and feels bigger to me but skinner....
  13. TROFFER88 Husqvarna
    Camas Wa
    2008 and up are full size frames
  14. Norman Foley Husqvarna
    I think my post pretty much says it all.... same part numbers.
  15. rockdancer Husqvarna
    Is that official Norm ?
    Ive heard it said many time s the frame size went up but here is a video on KTM range that a local guy Barry did that also mentions this
    I guess there is a lot of misinformation and rumour spreading on the net
    If this is the case - Id recommend taking a 200 for a decent ride or buy a ktm200 to see if you like the motor and then do the swap .
    View: https://www.youtube.com/watch?v=sklSQlLFSsY
  16. Norman Foley Husqvarna
    I looked up the part numbers on KTM parts site.... I don't think part numbers lie!
    125EXC and 200EXC EU and Australia models all have same frame part number. 200XC-W US has a different frame part number, but not even similar to 250/300 frame part number.
    I can tell you one thing... The 125 and 250 frames are definitely different when you go to put rad guards on and adjust the steering stops. 125 is shorter from the steering stem, back to where rads mount. At some point the overall size of the 125/200 frame, may have gotten bigger and more similar to 250/300 frame, but they are not the same frames.
  17. racemx904 Husqvarna
    owenton, ky
    the mount are going to be different
  18. robertaccio Husqvarna
    San Diego, Ca
    Brad's 200cc converts are 150XC (linkage bikes) based, so built up from that chassis.
  19. Norman Foley Husqvarna
    I rode a new box stock '16 200XC-W today. I was impressed with the motor for sure and I now want one. It seemed almost as powerful, as my '12 Husaberg TE250. The rest of the bike.... I'm not so sure. I guess the key words are... box stock. My box stock '15 TE125 felt much better and is now way better with suspension done. I would have to do some dialing in on the XC-W to get it working right, as it felt really nervous. What surprised me the most, was that the OC forks felt terrible. I'm 180 naked, so I guess they were settling too far into the stroke, with the stock springs.
    I could do a 200 build on my TE125, but I really want the button. At 61 life is too short, so I'm buying a '16 200XC-W and swapping engines! TE200 with the link!
    When the '17 TE's come out, we'll see what that brings for small bores, but until the.... old tech rules!:oldman:
    ks9mm, wallybean, rockdancer and 3 others like this.
  20. racemx904 Husqvarna
    owenton, ky
    Been there done that on the PDS wont go that route again....
    Prolly just going to do the 125 and just have another bike that I can switch for different races or rides
