Beta, Beta, and more Beta!
Discussion in 'Non-Husqvarna Motorcycles' started by water racer, Nov 1, 2013.
  1. GMP Husqvarna
    NJ
    '13 Beta 300RR Racing
    If your refering to the pic I posted, yes, its an MT-16. Whats interesting though is the bike is so smooth that anything seems to work pretty well once you ditch the stock FIM tire. I'm all ears for a good sticky front tire if you find something better than my default M59.
  2. Connor Husqvarna
    Maryland
    '12 TXC310
    Have you tried the new AT81 front? Ive heard some good things about it. I want to try one.
    hawaiidirtrider likes this.
  3. siaknijustin Husqvarna
    Blanding, Utah
    None
    '05 GasGas EC300
    Glenn, fwiw, trail rider magazine just tested the new Dunlop geomax 81tires and said they work well in your neck of the woods.
    LandofMotards likes this.
  4. Motosportz CH Sponsor
    M59 is a great tire IMHO for what I do. I like the Motoz Terrapactor front better. Both those are top choices for me.
  5. GMP Husqvarna
    NJ
    For the rocks, roots, and more technical trail stuff like your PNW conditions its great. For some of the faster HS courses, especially loose flatter turns over hardpack, I'd like a little more bite. I think the fork is a little light on rebound valving though, which I will correct ASAP, so this may have a lot to do with it. That said, the Pirelli XCMS I had on before didn't care as much. That AT81 is supposed to be a stiff sidewall/soft crown tire, should work good Tubliss which is all I run.
    FWIW to Husky guys considering Beta, your wheels(right side drive) will fit. I bought a set off a member here and had custom stainless sleeved spacers made.
  6. water racer Husqvarna
    http://www.knoxenduro.com Knoxville, Tennessee
    2013 Beta 250RR
    2009 Husqvarna WR125 1997 Fantic
    Are you referring to wr250-300 wheels? I tried my 125-x-lite wheels and they don't fit, axle is way to big.
  7. GMP Husqvarna
    NJ
    Thats funny, wheels I have are supposed to be from a WR125. Axel is 20mm, you need custom spacers or the Beta spacers/seals with a 1.5mm washer on the sprocket side. My brother has a TXC310 XLite, will compare ASAP.
  8. Motosportz CH Sponsor
    Maybe an older husky wheel. The newer ones have an almost 25mm axle.
  9. GMP Husqvarna
    NJ
    Not familiar with Husky axel/spacers, but the Beta spacers as well as my specials have a 25mm OD that fits in the ID of the bearing to the shoulder, like a KTM or GG spacer. Does a Husky axel ride directly in the bearing ID? If so there is your answer. The older wheels supposodly have something on the brake side of the hub that does not fit. Hammer can tell you exactly, he did it first and sold me my set.
  10. Motosportz CH Sponsor
    Yep, husky axle rides on the inner race.
  11. hammer Husqvarna
    The wheels GMP has are off a 09 125. The Beta axle must be used. You can use the Beta factory spacers and seals in the Husky wheels with a washer or make up some spacers to use with the Husky seals all very easy stuff. I have even had my Husky SM wheels on the Beta.
  12. hammer Husqvarna
    Your X-lite wheels will work. That what I have on my Beta.
  13. Motosportz CH Sponsor
    The axle is a lot smaller on the Beta but the stepped axle spacer (like KTM) makes them work.
  14. hammer Husqvarna
    If this is a question, the answer is yes.
  15. water racer Husqvarna
    2013 Beta 250RR
    Ok, thats good, I will give it another try.
  16. GMP Husqvarna
    NJ
    Like Hammer said, very easy. If you look at the Husky hubs compared to those on the Beta, they look the same with the exception of some secondary machining on the Beta parts.
  17. Motosportz CH Sponsor
    Seems Beta borrowed a lot from KTM and a little from husky.
  18. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    More like Beta did a bunch of R&D for KTM and shared info with Husky brothers. :D
  19. Connor Husqvarna
    Maryland
    '12 TXC310
    As much as I like Beta, I think it may be the other way around. KTM did the R&D and others benefited.
  20. GMP Husqvarna
    NJ
    They mfg a lot of stuff for KTM. I also tend to think that they may have designed some as well. Seems like the relationship would not be so cozy if there was blatant piracy of some of the designs. Stuff like wheels are just off the shelf componentry. Probably easier to use the same foundry in Italy that cast the Husky hubs.
