Bike weights - 2000 Husky WR250 vs 2003 Honda CR250R
Discussion in 'General (Main)' started by letitsnow, May 6, 2011.
  1. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    sounds light to me. my '03 CR205R weighed 230'ish with PC sparky muff, UFO pro-guard barkies, IMS 3.2 gal tank half or so full, MS bashy, rad guards, HD tubes, 11oz FWW, 15' of paracord on the X-bar etc etc. it was 220'ish dry if i recall and claimed was 212#!
    honda lied, like the rest sans KTM, about 10# till about 2009 i think...then they got "ready to ride" weights and those were pretty on target.
    WR's are robust, steel frame enduro ready for the most part. get a lot more for your money and spend less generally as well. my CR off-roaders (more than one...) ate stuff like plating coming off cylinders before a ring wore out (yes jetting was correct), wheel brgs, hubs, rims, fork seals, c/s seals, shock seals, frames, etc...those allum perimeter frames sucked balls. hubs and bearings were garbage too. the 03 motor was way better than the 04 off road. they were close but i really liked the 03. that 03 was a killer gnarly bike. 04 was ok, but, the 03 was great.
  2. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    I'm not really worried about my scale being accurate because it was a comparison - both bikes were weighed on the same scale...
  3. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    2009 RMZ450 2005YZ250 2001 EXC300
    I don't worry about one bike being a few pounds heavier than another. I think what is more important is power to weight ratio and center of gravity. Power to weight ratio is pretty self explanitory. When the center of gravitiy is lower on a bike, it will feel lighter and hook up better than an equal weight bike with a higher one. That what makes 4 stokes (camshafts and valves) feel so heavy and makes them harder to turn. Add a starter and battery, and its even worse. I just got back on a 2 stroke after 2 years on a 450, and I'm already way faster with results to prove it. Can wait to get used to the bike.
  4. pvduke Husqvarna
    ... on the gas...
    maybe the scale i was using was off. if its really 217, i might have to go get me another one! i do get pretty weight-weenie when it comes to pedal bikes. ill fish-scale every part during my build lookin' for the lightest ones etc...yeh, i know, not healthy and obsessive...lol.
    motoman hit it on the head too with the moving parts thingy...
  5. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    My '93 CR125 weighs 220 (ready to ride) on the same scale. Not that it matters much, but it is fun to compare stuff!
    I suspect that I would have been just as fast (as I am on the Honda CR250) on the Husky WR if I had put the CR ignition on it. Riding style matching a motor that spools up/down faster was probably a bigger factor than the weight difference...
  6. pvduke Husqvarna
    ... on the gas...
    egzacarhy! weights are subjective to a lot of factors. you make an excellent, valid point!!!
