BMP Case Saver for 610
Discussion in '610/630' started by jckid, Nov 24, 2009.
  1. jckid Husqvarna
    California
    Previsouly owned: SM610
    WR250X, KLX351, CT110
    I probably will. It looks like it will work, but the bolts that came with the case saver are too short, and the stock ones are too. So I need to see if I can find the correct length of bolts. I might have time to do that today. I'll also ride the bike today or tomorrow just to make sure the chain isn't going to make contact. I'll let you know...
  2. jckid Husqvarna
    California
    Well I went for a ride today. The chain did not rub on the case saver at all, so it is compatible with the 15T countersprocket.
  3. High-Side Husqvarna
    Let me know what bolts you get that work because I ordered the same case saver and I'm going to put the stock cover over it too. :thumbsup:
  4. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    I'm going to give a go at making my own.................. for clearances can any of ya'll tell me the tip to tip measurement of a 16T and 17T front sprocket?
  5. jckid Husqvarna
    California
    I just finished it. What I ended up doing was taking the stock lower bolt and moving it to the upper position. It seemed to be just the right length. For the lower position I bought a M6-1.00X65 bolt. It seemed a tad long, so I added two washers. I did this after my ride today, so I haven't ridden it this way, but it should be fine. Of course it does move the plastic cover out farther than stock, and it feels like my foot might rest against it, but that should be ok. Here's a pic:
  6. High-Side Husqvarna
    That looks good. :thumbsup:
    Thanks for the heads-up. :cheers:
  7. Bones Husqvarna
    Cedar Rapids, IA
    How thick is that case saver? 3/8"? I am considering whittling one out some time.
  8. husky666 Mini-Sponsor
    So California
    That looks good,can you measure the distance between your shifter and the front of the foot peg.I was considering those pegs but they look closer to the shifter than the stock ones.
    Thanks
  9. High-Side Husqvarna
    Does anyone have one that's running a 16 tooth counter sprocket?
  10. jckid Husqvarna
    California
    I'll try to remember to measure at lunch time today. I have the pegs mounted in the regular position. If you mount them in the lo-boy position, I think that moves them down and back to accommodate larger feet.
  11. jckid Husqvarna
    California
    husky666,
    Looks like it's about 4". Thought a pic might be helpful...
  12. husky666 Mini-Sponsor
    So California
    Very helpful,thank you.
  13. gsuburban Husqvarna
    Here's a sample image:
  14. Coffee CH Owner
    That does indeed appear to be a sample image, did you want to post up a case saver picture?
  15. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Ive been looking and listenting to the case saver discussion. mte here, had te idea to tie it to the roller or subframe. After getting into it, I saw that the existing bolts and their cast bosses, look very vulnerable to me.
    I see my front sprocket is getting pretty loose, is Ironman the sprocket that comes with a good tight fit?
  16. dubbs Husqvarna
    Ontario
    I only had my cover off once and that was when I first got it. Remind me, does the TE not come with a case saver already or is it just the plastic cover. Also, what is the stock tooth number for the TE. I thought guys would go to a smaller front sprocket to get more torque.
  17. LRPct Husqvarna
    NW connecticut
    for an 08 610 at least, stock sprockets are 15 and 45. I went to a 47 rear and think that gearing about about perfect.
