Clutch Basket for a 2009 wr 125
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by yaackles, Apr 24, 2016.
  1. yaackles Husqvarna
    Finger Lakes Region of NY
    2009 WR 125, 1986 WR 250
    79YZ100,79KZ650,83Nigthawk,98rmx250
    The inner small gear on the basket that connects with the kick start gears.
  2. yaackles Husqvarna
    OK How Much ?!?!
  3. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    About as much chance of finding one of them as there is finding a pile of warm rocking horse $hit lol
    I didnt think that gear was/is removable. I have personally had 3 of them go belly up on me. One cracked around a tooth. one sheared a tooth and the other is a bit mangled from a tooth from the idle gear snaping off and wedging itself solid - that one also bust the cases around the idle gear shaft and is still scattered all over the bench awaiting the rebuild, As luck would have it I have a new older type complete basket but need the crank gear to suit as they are not the same as the later item and do not mesh at all well.
    yaackles likes this.
  4. yaackles Husqvarna
    Sounds like we are in a similar predicament !!!
