krussell
Strada Adventurer
If I did this right, you should see a rough video of the route I used for the clutch cable.
You did it right. Thanks for posting.
I would imagine you're not doing clockwise donuts all day long and the cable would be touching only for moments at a time, so probably okay as far as heat goes. Check it in a 1000 miles and let us know!
When I got home from work today I rerouted my clutch cable behind the frame. Much more relaxed, but there are a couple of spots where it will rub against the radiator hose when the bars are on full right lock. Does anyone foresee that being a problem when the hose gets hot ?
I decided to at least reverse the little doohickey and expose the cable to the side that hadn't worn away. A little mind logic later I couldn't find any reason to not just keep bending the bracket and fashion a clamp out of it.
It's just a rehash of various other similar ideas including:That picture makes me cringe. Much better to be loose than tight in my opinion. At my 20,000km service it looks like the dealer put a new oem cable guide on my bike & had it sitting 'un-bent' like the 2nd generation TR's went out with (mine was bent around the cable when I bought the bike). Maybe a memo went out to dealers about this issue?
Based on my experience, you will not have any problems with steering. When you turn right, the cable will want to move downward. When you turn left, the cable will want to move upward. I chose to install a clamp that holds the cable firmly at the top of the radiator to prevent the cable from moving at that point. This also prevents the cable from moving significantly at the bottom of the radiator, another wear point. The cable still has to move somewhere when you turn right and left, however. By clamping it at the radiator, the cable will now bend and move towards the headlight above the radiator. There seems to be plenty of room on my stock bike for this and it does not impede steering. It is your choice whether you put on a tight clamp or loose one, but either would be better than the stock guide, IMO.
I did the same, ran it on the right side along with some electrical loom.. Couldn't make it work routed as described by others... Have 2 inch risers so it was extra tight in there... At 1200 miles my cable is showing some wear at the top but is cut pretty deep where it was in contact at the bottom of the radiator.. Patched it with some shrink tube and electrical loom and a few zip ties then ran the whole thing on the right side behind the radiator. Will ride it this way until I get a new longer cable.I just routed it on the right hand side of the radiator mount so it's not being forced up and down, it just moves sideways left and right.
I am really glad I saw this thread, after 400k's my factory clamp has worn the rubber off and the sharp metal edge was having a good old nor at my cable outer. Seeing what others had done I decided clamping/locking the cable is the wrong thing to do as the cable floats/slides up and down about 2" from lock to lock. If you fix it it pushes into the back of the headlight and other cables and is just yuk. I also re-routed the clutch cable under the headlight wires ...this puts less strain on both and is how it should have been.
