125-200cc Clutch slip on 165
Discussion in '2 Stroke' started by rockdancer, Nov 24, 2013.
  1. Motosportz CH Sponsor
    I know springs will sack some, seen it on shock springs a few times. I can also see this maybe happening on 4 strokes where they are bathed in hot oil. thats said never had a clutch spring issue in 30 years and countless bikes so not something i worry about personally.
  2. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Right on guys. As always I say do what you believe in and what has been working for you. I have learned over the (more recent) years that my view of "correct" may not fit everyone's situation or use, that the same materials and designs produce different results for different people. We sure do use our machines in vastly different conditions and ways!!
    I have personally proved the loss of clutchpack pressure myself. Back when I was one of the "top dogs" locally in 125A and 250A(that alone dates it, now 250A and 450A!!) , my 125 starting slipping bad in practice. I had fresh OEM springs (Honda CR125) but no plates. Threw the springs in and got through the raceday with no more slipping. Replaced the pack later and it was beat.
    Some interesting info on the very real occurance of both spring fatigue and spring relaxation, both of which affect clutchpack pressure:
    http://www.rockfordspring.com/relaxationofsprings.asp
    http://www.rockfordspring.com/springfatigue.asp
    I feel that in this bike IN PARTICULAR, it has very little wiggle-room for the springs, as they are just barely adequate when new, for the way I ride. Again, disregard if you never have the problem, but I mention all this because the OP IS having a problem! The springs are cheap compared to the clutchpack, so it makes economical sense to replace them.:thumbsup:
    Motosportz likes this.
  3. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    Marc, I agree with the "theory" of what you're talking about, and maybe if you're right on the edge it can happen. However, as shown in those links, the amount of relaxation we're talking about is only 1-5%. On the fatigue, it's impossible to say if we have an issue unless we have a bunch of engineering data about the springs. Also, note that the number of cycles to failure is on the order of 1 million; even at 1000 clutch actuations per ride (every 7 seconds of a 2-hour hare scramble!), it would take 1,000 rides (maybe 30,000 miles?) to get a spring to fail. Unlikely anybody here rides a 2-stroke this much! :cheers:
    MotoMarc36 likes this.
  4. Motosportz CH Sponsor
    Marc, agree with everything you said it is just my experiance with this clutch (I've owned about 5 125 huskys now) and the lack of any posts but this one about it makes me think the clutches are strong on this bike. There is over 100 165 kits out there making big power and no stream of clutch related issues as you would assume might be the case. I ride nothing but tight technical steep stuff and abuse the clutch as part of my normal riding. No issues with springs ever. I think the OP might be dealing with a odd lever and issues. In the end you are 100% correct, they are cheap, replace them if you think it might be the issue. :thumbsup:
  5. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    So there is no notching on the basket
    I have nt really ever smelt burning and the plates aren't blue -would that be when hot?
    I am not sure if the worn friction plates are really worn too much or if issue is related to the asv lever
    Any thoughts on wear and pics?
    As i said I will also do a flush and try best quality oil.
    If springs are cheap enough will get new ones with plates if i need them
  6. MotoMarc36 Husqvarna
    wisconsin
    Many. Too many.
    Good convo guys!
    RD if your measurements were accurate and you are below min spec on the frictions then by all means replace the pack and springs, it is probably the problem. Remember, as the pack wears it gets thinner, which effectively is reducing preload on the springs also. I would definitely go back to a stock perch/lever with stock freeplay, at least until you establish a baseline to work with on the new clutch. That info, combined with all that people have shared here, will give you the knowledge to make an educated decision on wether the ASV is going to work for you properly. Kelly's tip on oil is huge, only use an oil without friction modifiers. If you are unsure what to use, ask here or only use a 2t gearbox-specific oil. If it says "energy conserving" it most certainly has friction modifiers and is the enemy of clutches. Even if it only got used once, it compromises the clutch for ever. Perhaps this happened in the distant past?
    rockdancer likes this.
  7. rockdancer Husqvarna
    Yes I think my oil choice has been without that knowledge in the past
    The wear would have been over the last few years as a 125 then 144 and I guess the torque of the 165 is showing the issue up
  8. Motosportz CH Sponsor
    Spectro clutch saver is very good trans oil for these bikes. BTW your steel plates look fine from the pix.
  9. rockdancer Husqvarna
    Cleaned up the plates with some emery cloth and put in some new quality gearbox oil
    Changed clutch lever which allowed me to reduce middle cable barrel about 10mm
    Clutch seems to work perfectly now
    Message - dont use ASV. levers.
  10. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    :thumbsup::thumbsup::thumbsup:
    These clutches are pretty indestructible if you ask me
    I had with my last overhaul notches in the basket which I filed out
    I have a new basket on the shelf now but still don't see the need to replace it
    I do use the bike where it is made for and do respect the oil changes and so, but its amazing how much this little engine is taking the load
    Robert-Jan
  11. rockdancer Husqvarna
    Yep.
    Re measured the friction plates and they were all 2.9mm so only 1mm of wear in 100 hrs or so
    Went on a big ride in the wet and she is going real well. Impressed a few people with its grunt
    Mind you another guy on a new wr125 was there and rode his bike up hills better than most on 300s
  12. Hoov165x Husqvarna
    Carlton, OR & Sunriver, OR
    The Latest: 2014 FE250
    No issues on mine with ASV lever. I get full release and full engagement. No matter though as I have my hydro clutch on the bench waiting to be installed!
