Cold Start Issue
Discussion in 'TR650' started by Pepe, Jan 13, 2015.
  1. danketchpel Husqvarna
    Camarillo, CA
    Terra 650
    Moto Guzzi, Ducati, Beta
    I recall noticing the problem more after I did the exhaust and POD Mod. I had be running the bike stock but with the PC5 setup and it was starting pretty well most of the time. Then I did both mods and it got a lot more finicky about starting. I've tried all kinds of settings in the PC5 and nothing has really fixed it. What seems to be most effective is taking out lots of fuel just for startup. I have a crazy setting of like -25 just below idle (cranking speed) to lean it out for start up, and I think often it's still getting too much fuel, or not enough air, which might be more likely. But if you hold the throttle open it doesn't work either.
  2. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Hey Dan, is it kinda like this??
    View: https://www.youtube.com/watch?v=1ua6ALDFvjw
    First two tries are with no throttle. Last one is with the 1 RCH. Works every time and doesn't cost a dime!!
    BTW, My Ural starts perfectly every time that way and it has carbs...
    I hesitate on messing with the with the throttle plate stop screw or the TPS because the idle is so solid hot or cold and right in the RPM range. A slight twist of the right grip is so easy to do.
  3. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    What's with the tiedowns? earthquake proofing ?
    PaulC likes this.
  4. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Yes!! $3000 damage to my CBR 1000F in 1994 .
    PaulC likes this.
  5. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Mine was exactly like that for several months last winter/spring.
    It was very random when it would happen, maybe 1 or 2 starts in 30 or so.
    Just a touch of throttle though and it would fire off fine and had no signs of any running or idle issues.
    FWIW my carbed DRZ, like your ural, needed a little twist as well to fire, without cracking the throttle it would not start most times.
    I had not had any issues with this for months with my Terra, yet yesterday it did it again.
  6. vodka Husqvarna
    South Australia
    TR650 Terra ABS
    R1200R , Yamy WR250R
    I always had to turnover twice with throttle + when starting cold...always no matter what the ambient temp was. With Power commander and autotune starts first time. I know the cost is prohibitive for most and another solution may be far cheaper but a side effect of pc and at was that. May help direct to a solution in your case.
  7. Pepe Husqvarna
    Los Angeles
    05 BMW 1200GS
    I went to BMW Riverside yesterday. Eventhough they have never been a Husky dealer nor purchased the MOSS system for the husky, they can diagnose any faults with their existing BMW computer system. From what I understood, same software that deals with the 650GS can diagnose our bike.
    They checked for faults, one appeared at the beginning but then it cleared just by starting the bike. Then did a reset and then where able to do an update. Reset the throttle sensor.
    The bike still is not starting right.
    I found out previously that two other TR650s had gone there to be checked and that's why I went there. So, if this guys can do it, then every BMW dealership should be able to check our Huskys.
    I dealt with a guy called Kyle. Super nice guy and very helpful if anyone needs to talk to him about this.
  8. danketchpel Husqvarna
    Camarillo, CA
    Terra 650
    YES... you video captures EXACTLY how my bike "trys" to start when it's cold. Whew... I thought it was just me or my setup, no it's some funky biz with the ECU programming, possibly made worse with pipes or air filter mods, not sure.
    I am beginning to understand it needs a bit more air, just a bit, for a good cold start. What seems to be working good for me is on about the 2nd revolution just barely crack the throttle for one revolution then close it. Then it seems to catch and idle fine.
    I can deal with it if I find a consistent routine that works. I've had so many bikes and most are pretty easy to start, but some have "routines".
    I haven't had trouble starting my other FI bikes, only this one. All the carb'd bikes, no problem once you jet them correctly. The trickiest 2 bikes I've had to start were my BSA 441 and a Yamaha SR500. Both required a bit of a routine.
    The funny thing is usually you can get an engine to start very easily. I've started engines just by squirting gas down the carb throat and cranking, very crude. It's kinda like the old British Amal carbs with ticklers that just flooded the venturi. But you know what, it worked.
  9. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    It stands to reason they need a touch more air when you increase the fuel( PC 5 or AIT spoofer ) and increase exhaust flow ( GPR or Deamon).
  10. Fort Husqvarna
    2013 TR 650 Strada
    79 Honda XL100, 09 BMW R1200 GSA
    Hi Pepe.
    This is good news.
    Do you happen to know the name/model/version of the BMW Diagnostics tool the dealer was using?
    What else can the system do.
    Cheers!
  11. Pepe Husqvarna
    Los Angeles
    05 BMW 1200GS
    It is good news!! All I know is what I wrote above. It's their system that is used for all their BMW bikes, though from what I understand he used the 650GS software to diagnose the Husky.
    If you want to know more, call Kyle at the dealership, he is a really nice guy: (951) 353-0607
  12. danketchpel Husqvarna
    Camarillo, CA
    Terra 650
    Thanks for the feedback and info.
    It's good to hear there is a helpful tech at a BMW dealership. The local BMW shop didn't want to touch my bike, they kinda have a sour attitude to be honest.
  13. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Our Husky dealer didn't even know what a Moss tool was when I asked them!
