Countershaft Sprocket Puller Recommendation
Discussion in 'Vintage/Left Kickers' started by motorick, Jan 3, 2018.
  1. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    Rather than risk damaging any component with excessive heat, I would cut the sprocket off with an exhaust cutoff wheel in segments close to the countershaft without touching the CS, but allowing the segments breaking off freely.
  2. motorick Husqvarna
    Jacksonville, OR
    1974 400 CR, 1987 250 XC
    1973 Norton Commando
    Update on my saga... Andy replaced the broken arm (thank you!); but, unfortunately I broke the other one, sigh... So in the following months I've been soaking both jugs ('72 250 & '73 400) and continuing trying to remove 2 each pesty head studs. Got the 2 out of the 250 (yeah! IMG_0252.JPG View attachment 88113 IMG_0252.JPG IMG_0253.JPG ), but broke my stud removing tool on the 400. Are you seeing a pattern here? Found a countershaft tool on ebay and arrived today. First let me bask in my glory: it removed the 250 sprocket first try : ) . I believe the tool I purchased is the aftermarket 'hi point' as the legs are shorter than the one Andy has. So... on to the 400 and... the sprocket broke (at least the tool didn't : ) . So now I have a piston still stuck in the jug of the 250 and a broken sprocket and 2 head bolts stuck in the 400. Patience is definitely a virtue on these age rusted projects.
  3. Vinskord Husqvarna
    400 CR
    Good update - that Hi Point puller is a find. Never have seen a sprocket snap before a puller. You could rent out that tool and recoup your cost on pullers!
    motorick likes this.
  4. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    I think its time to cut off the sprocket and if needed replace the shaft. Theres good availability of reasonably priced 5 spd trans parts on Ebay. 5 spds were used on all 250, 360, 400, and 450 motors from 72 and 73 plus the 74 CR's, the 74 WR's had six speeds with exception of the 450WR which stayed with the 5 spd. You may even get lucky and find a 74 250 CR 5spd spline countershaft. If you're going to ride cross county another option would be to put a 74 six spd in it.
  5. squid on a 300 Husqvarna
    York Springs Pa
    72 WR 250 79 CR 250
    GAS GAS 300 Trials 2 KTMs 2 Hodakas
    Marty Strauss at Paradise Cycles in Renyoldsville PA machined the tapered output shaft on my 72 WR 250 to accept a later model splined counter sprocket..Makes finding replacement sprockets a lot easier also..
    Bob
    Crashaholic likes this.
  6. Dave-cr125 Husqvarna
    Gloucestershire UK
    Cr125 1972 and 1976
    Triumph t150 1972
    The same thing happened to me on a 72 125. I had the correct puller and broke it trying to remove the sprocket. The safest thing to do is grind the sprocket off, then replace it. I put a splined shaft in the 72 125, same as later models so that it wouldn't happen again. Don't know if you can do that.
    Good luck, Dave
  7. 390wr Jon Husqvarna
    New England
    1980 Husqvarna 390WR
    1979 BMW R100RS
    So now I have a piston still stuck in the jug of the 250 and a broken sprocket and 2 head bolts stuck in the 400. Patience is definitely a virtue on these age rusted projects.[/quote]
    I have always had good luck freeing a seized piston with brake fluid.
  8. markt2 Husqvarna
    Nevada
    1976 250CR (times 2)
    Several vintage Yamahas
    Great update! Amazing what a different puller can do... good luck on the rest of your challenges!
    Many years ago John at Vintage Husky gave me a splined trans output shaft to replace the tapered shaft on my 73 250... Not the whole later 6 speed trans, just the shaft. Not sure if it was something special or not... I was under the impression that the output shaft on the early 6 speed could be used in place of the 5 speed tapered shaft. Might be something to look into?
  9. squid on a 300 Husqvarna
    York Springs Pa
    72 WR 250 79 CR 250
    I have always had good luck freeing a seized piston with brake fluid.[/quote]
    Try this on your stuck piston
    http://www.cafehusky.com/threads/79-cr-250-rebuild.87604/
  10. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    as mentioned before, just just the sprocket with a cut off tool to just shy of the shaft, then strike with a chisel. done deal.
  11. motorick Husqvarna
    Jacksonville, OR
    Thanks to all for encouraging words! The reason I'm hell bent on removing the '73 400 sprocket is so I can swap out the drive shaft with a '75 400 WR one I have and have a solid 400CR engine for a spare (or a backup bike) for my '74 400 CR which I hope to someday race (ok, parade) at selected AHRMA events. This is the pile of bits that all this started from : )
