125-200cc CR125 and 144 scored piston and cylinder (Pics and vid)
Discussion in '2 Stroke' started by High Society, Jan 4, 2014.
  1. High Society Husqvarna
    2010 TC250
    2001 DRZ400sm
    Thank you for the info. I have a question about doing a leak down test. Will air leak out due to the power valves? Giving me a bad reading?
  2. Motosportz CH Sponsor
  3. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Just to clarify, I didn't mean to imply that Maxima oils are bad, I honestly believe all oils are good for their intended purpose.... I just think there might have been a compatability issue somehow and would switch oils AND fuel sources to rule out the problem.:thumbsup:
    Of course, I have been using Klotz R50 so it must be the best!:rolleyes:JK
    High Society likes this.
  4. High Society Husqvarna
    2010 TC250
    2001 DRZ400sm
    Maybe I will mix Amsoil and Klotz? That should be the ultimate luberfacation! I was running 91 from Shell- "V-power". Contacted a replating service. I will send it off soon. I haven't ridden in wayyy too long.
    MotoMarc36 and Motosportz like this.
  5. MotoMarc36 Husqvarna
    wisconsin
    Many. Too many.
    Klotsoil. I like it!:thumbsup:
    troy deck likes this.
  6. High Society Husqvarna
    2010 TC250
    2001 DRZ400sm
    Got the bike back together. I left the pv linkage cover off. Should I be able to see it move during idle or quick blips?
  7. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    no the power valve opens at around 6000 rpm
  8. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    For comparison, my own '12 144 would require a 480-490 for hard sea level desert running. And don't forget the needle... what needle and clip position have you bee running?
  9. High Society Husqvarna
    2010 TC250
    2001 DRZ400sm
    The needle is 6DEY15-74. The clip is in the 3rd notch. I've put 15 hours on the rebuild without issues since going to a 490 main, and 40 pilot. My pro circuit pipe had an exhaust leak at the bracket weld. How bad can this effect the bike?
  10. Motosportz CH Sponsor
    almost not at all.
