Crash Test Dummy
Discussion in 'TR650' started by HARDER1, Feb 4, 2013.
  1. FabOneUp Husqvarna
    Pikes Peak, Colorado
    '13 TR650 Terra
    '14 KTM 450 XC-W '11 BMW R1200GS
    You are a true adventure rider! Please show us the repairs when you are done....no matter how they look. The black plastic came directly from Husky and are for the Strada. They come without the decals which is fine for me. Ken liked the look without the decals and we pulled his off with a heat gun while he was here. Cost should be around $120 for the set, but your dealer may cut you a better deal. I may have to go in early tonight and pull out a movie!
  2. HARDER1 Husqvarna
    Tacoma, Wa
    DRZ400S
    Here's my JB Weld Bodge Job so far: I'll be putting her clothes back on tonight and see what the strength is like on my next ride...
    Some of the Broken Bits & my license plate shrinkage. The red reflector already had holes drilled-so the Enduro Engineering plate mounted right up
    FabOneUp likes this.
  3. HARDER1 Husqvarna
    Tacoma, Wa
    DRZ400S
    The main radiator mounts were broken as well as the shroud mounts on top. My last JB session was on the frame mounts. I just used 550 chord to hold the radiator in place while the JB dries.
    On the bright side, this beauty showed up from Down Unda'
    nev.., fleche phoenix and FabOneUp like this.
  4. FabOneUp Husqvarna
    '13 TR650 Terra
    Looks great! I have never used JB weld on plastic. It looks like it should hold up nicely. Let us know how the test run goes. You went from "crash test dummy" to "lab rat".:D
  5. Thumpa Husqvarna
    san francisco bay area, california usa
    TR 650 Terra
    CCM Dakar, G650X
    The trick is keeping stuff firmly in place long enough to set. Seems like you done a stout job by all impressions! Maybe you could tell us how you like that B+B Bashplate once you've fitted it and bashed it round a bit!
  6. HARDER1 Husqvarna
    Tacoma, Wa
    DRZ400S
    I put the bike back together last night and the Radiator is holding well. But, that doesn't mean I trust it! I'll take the bike out and find some whoops to strength test the cold welds. I'm still going to figure out a better way to hold the Rad to the upper mounts. I also put the B&B on last night. What a sweet bash plate! I'll post pics in the Skid Plate options thread, but here's the bike back together. Cheers!
    pvduke, mario33, nev.. and 1 other person like this.
  7. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    Now that SW Motech have released some pictures of their Terra Accessories, it looks like their crash bars are designed to be fitted with a bash plate in place using both of the engine bolts on the frame. (or at least this is my interpretation of the images and their installation instruction diagrams)
    SW Motech crash bars
    http://shop.sw-motech.com/cosmoshop/pix/a/n/sbl_03_319_10000__b1360666928-3167.jpg
    SW motech crash bars installation
    http://shop.sw-motech.com/cosmoshop/artikelpdf/sbl_03_319_10000_b.pdf
    SW motech bash plate installation
    http://shop.sw-motech.com/cosmoshop/artikelpdf/mss_03_325_10000_b.pdf
    These look like they should go straight on with the B&B Bashplate
    HARDER1 likes this.
  8. HARDER1 Husqvarna
    Tacoma, Wa
    DRZ400S
    That's what it looked like to me too nev.. I was excited to see they didn't use both engine mounts so that we could use other plates etc. The upper of the two bolts may be an issue for spacing, but we can probably work with it. I have my request in at SW Motech, but I think it will be awhile before we get them. They look perfect for my needs.
  9. nev.. Terrarist
    '13 TR650 Terra
    '14 XT1200ZE
    If I'm reading those fitting diagrams correctly, there are 5mm spacers on both sides where it mounts to the upper bolt, which I presume would be omitted if the Sw motech bashplate was fitted. Looking at their bashplate instructions, it's design and fitting looks very close to the design of the B&B, so I think there would be no clearance issues, and possibly the only adjustment I see might be necessary might be the size of the spacer used if their upper bash plate mount thickness was significantly different.
    I've just emailed the Australia SW Motech importer for any info they have on price/availability here.
  10. Toyboy Husqvarna
    Middletown, PA
    2011 TXC250/2012 TXC310, 2013 TR650
    BMW Hp2E/Yamaha Super T/BMW R1200RTP
    Hey harder1, I am pretty sure that that rad is the same as on the F800GS and the F800ST. Several on ebay, take a look and compare since you had yours in hand, you would be the better judge. Would be good to know which may fit for the "interchange ' list. Good luck with the repairs.
  11. Motosportz CH Sponsor
    Bring some zip ties. Been using JB type stuff for years and always found it useful for getting home or saving a ride but not long term solutions. My opinion only.
  12. HARDER1 Husqvarna
    Tacoma, Wa
    DRZ400S
    I agree with you Kelly. Operation zip tie is in effect for backup. I drilled two holes on the plastic tab in the center of the upper plastic frame. There are holes beside the upper brackets and I made a zip tie loop on each side. That should keep things in place and on the fram post. For now...
  13. HARDER1 Husqvarna
    Tacoma, Wa
    DRZ400S
    The JB has been holding fine on some rides, but I backed them up with zip ties on each side. 100% not sexy, but it works fine and is solid. The lower frame post carries the weight in the up and down loads. It's the side shots from tip overs and falls that will pop things loose. SW Motech crashbars are next. This is good enough for the girls I date :cool:
  14. FabOneUp Husqvarna
    '13 TR650 Terra
    That's good news! Did you ever price the radiator?
  15. HuskyKT Husqvarna
    Cape Girardeau, MO
    2012 TE 310 & 2013 TR650 Terra
    4 Suzuki GV1200 Madura
    Nice job getting her back together. I took a slightly different rout on the radiator mount (I also believe the F800 rads are the same but the mounts riveted to them are dif). I have a good friend in the HVAC business and he bent some aluminum channels which I riveted it the top and bottom of the radiator. I also riveted flat braces between the top and bottom. My first design mounting tabs did not work so I took some of the scrap aluminum and made the brackets pictured here. image.jpg image.jpg .
    I talked him out of some expended metal and made a guard which I attached to the front support straps. image.jpg
    FabOneUp, bluegopher and HARDER1 like this.
  16. HuskyKT Husqvarna
    Cape Girardeau, MO
    Radiators are around 200. I ordered one and it came in the next week. I just have not picked it up yet. Wanted a spare in case mine springs a leek.
