Damper / IMS solution
Discussion in 'Motosportz' started by Motosportz, Apr 19, 2010.
  1. Motosportz CH Sponsor
    It does...
  2. K7MDL Husqvarna
    Woodinville, WA
    But is too tall for underbar mount.
    For the record, the '07 TE610 is 60mm ID with about 6mm ring height for clamping. I have 10mm space between the tube and IMS tank (TE610). It is about 53 mm from weld on the tube to the top of the head tube above the triple clamp. The gas tank mount bolt center is about 35mm from the tube wall. The horizontal tube welded to the head tube is 32.5mm wide. The top triple clamp is 23mm thick.
