kurvenkrycher
Now that's interesting. However, I haven't been able to follow all your numbers. Where does the 1,79/1,70 inch travel come from? As the ABS ring has a fixed size, the travel between slots remains the same on all wheel sizes, just the passing time varies at a given speed.
Well, here's my logic, maybe I got something wrong. Hopefully my technically limited english will be sufficient to explain; haven't found everything I wanted in my preferred dictionaries:
The stability of a wheel and therefore the motorcycle is determined by its rotational forces which are directly related to the mass of the wheel and moreover its circumferential speed. A larger wheel therefore provides more stability at low speeds - the main reason why it is preferred by off road people?
For the ABS to react the time between the slots of the ring passing the photo sensor is the determing factor - as long as the tacho indicated a minimum speed before potential locking occurs. So at same revolutions of the ABS ring, the circumferential speed of the larger wheel is naturally higher due to the greater angular speed - it has more stability. In other words, when the threshold, at which the ABS releases the brake, is undercut (the slots passing by too slow), the tyres of the larger wheel naturally still have more stretch (=more outer speed) than its smaller counterparts.
In accordance, the 19 inch wheel will be travelling slower (on its relevant outside, the rims) and therefore be closer to the instablility realm as soon as the ABS starts its service. To put it different: The ABS reacts later. For sure the ABS has been set up to deal with this
But if you go down further to 17", the tyres/circumferential speed and therefore rotational forces MAY already be too slow before the ABS finally reacts, to provide the stability needed to keep the bike up. Not beeing not a sport bike and being from BMW, the ABS is most likely setup pretty much on the secure rather than hardcore side of things. However, more so for the 21 inch wheel than for its 19 inch fellow.
And, on the other hand, an even wilder GUESS to debate, the Terra ABS surely has not been set up for super sticky street tyres. So when you decelerate hard, albeit controlled, you may run into a unwanted releasing of the brakes, because a knobbie or touring tyre is already expected to be close to move over to sliding friction and therefore the ABS initiates a release. So from this point of view it still could release too early as opposed to my previous statement. But given the different friction of the various surfaces we travel on and that can't be determined, I really doubt this could be part of the ABS programming.
Lest we forget, an ABS is not a black/white loop that releases wheels after locking, but acts before the wheel potentially locks and therefore interprets the curves created by the passing of the slots and comparing those to its preprogrammed values.
Of course, I'll happily stand corrected, obvioulsy I am no expert at all. I just would be carefull with going too small. But it remains fact: I do not know.
Edit: Of course the instability of the wheel during slow rotation speeds is not an issue for the short time of its existence while braking and not the reason for the ABS, of course the locking is.
But the instable realm just comes before locking and is the part where I suspect the ABS to take up its work. So "instable" refers more to slow (or none) rotation of the wheel which is detected by the ABS. Could easily be misinterpreted in above post
