TE/TC Decoding Map Switch Position
Discussion in '2st' started by Captain Kirk, Feb 16, 2016.
  1. Tetley Husqvarna
    UK
    The hard map is switched by joining the map wires together, and the soft map by disconnecting them. If the OEM map switch is wired in, position 1 joins the circuit for a hard map, and position 2 breaks the circuit for a soft map. I have tested and verified this with a test meter.
    The difference between the two maps is very subtle, and in a lot of cases undetectable. I find the bike seems to hook up better on very slippery stuff with the soft map, although the bike seems to ride exactly the same.
    I would say that anyone who is experiencing a massive difference, or seeing higher power on map 2 is imagining it. A double blind test is required - A freind randomly sets the mapping to 1 or 2, (toss a coin, heads 1, tails 2) then tapes over the switch. You then ride the bike, and try to guess which map its on. Repeat 10 - 20 times, then study results. if the difference in mapping is clear, you should be right 100% of the time.
    I remember reading once, the any power differences less than around 10% cannot be reliably detected by seat of pants methods.
    Ps, the mapping on my old FI TE450 was very noticeable - the soft map just cut out the upper revs power band, I would say around a 25% loss of torque / power. I never used it, as if I wanted it to ride calmly, I used lower revs, where there was no noticeable effect with the mapping anyway.
    Husky_250 likes this.
  2. JBoone Husqvarna
    Charlotte, NC
    2016 TE300
    2005 ktm 300 exc (sold)
    :eek: So I may be correct?
  3. Tetley Husqvarna
    UK
    Yes, how you describe it is as it should be - very subtley calmer on map 2
  4. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Oh man im still in doubt (no offense) to whats what haha, the testemonies are always back and forth. Nice to hear you got bike dialed in though
  5. PLCGUY Husqvarna
    Sulphur, LA USA
    2016 TE300
    '13 150XC, '08 200XCW, '07 450XCW
    OK my 1st post (coming over from the 'orange side' w/ a shiny new '16 TE300. Re: the OEM map swich that is integral to the front brake master cylinder; since the documentation that came with the bike brand new 48 hours ago did not cover this I decided to figure it out for myself scientifically. the manual does mention that the black and the gray wire, that when plugged together (i.d. closed circuit) invokes the performance curve. Unplugged (i.e. open circuit) invokes the non-aggressive curve. I then broke out the Fluke 87-V multimeter set to 'ohms' and checked the continuity across the actual wiring going to the switch. Pos'n I = continuity (closed circuit). Pos'n II = no continuity (open circuit), so....putting two and two together we find that position 1 = performance and position 2 = non-aggressive. That was easy wasn't it!!!
    Husky_250, JBoone and reveille like this.
  6. JBoone Husqvarna
    Charlotte, NC
    2016 TE300
    Welcome and enjoy the new 300! I sure am.
  7. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    No, I switched back and forth several times while running and/or in motion.
    One of the keys that nobody seems to have mentioned is that there's a main map switch under the seat. The setting on that switch is for position two. If the main switch is set to position one or 4-9 it will be the same as position one on the bar switch. On my bike the main switch is set to position 3 (soft), so on the bar switch position one is "aggressive" (standard) and position two is "soft." Position one seems great for MX where you're wide open all the time, position two is better for...Well...Everything else.
  8. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    This thread is 2 stroke related so no switch under seat. Only the plug under the tank.
  9. JonXX Administrator
    You're right. So never mind about the under-seat/airbox switch!
    The fact remains, however, that on my 2015 TC250, bar switch position one (standard) is useless in environments other than an MX track, and position two (programmed soft) pulls hard and smooth from idle.
    reveille likes this.
  10. Tetley Husqvarna
    UK
    And that's exactly how I tested and proved it!
  11. HS507 Husqvarna
    NE Ohio
    Te 300
    Could be just me but tried both thos weekend (shutting off to switch between) and 1 seamed less radacle than 2, hmmm
