250-500cc Dodgy head orings?
Discussion in '2 Stroke' started by shawbagga, Dec 28, 2015.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Ahh good news everybody(Dr Nick Riviera). New orings in the other day n last day before I gotta go back to work so went for a strap on the 3 hunge this mornin(Monday am be mad not too!). No lost coolant yay! Purposely overfilled rad so it could settle itself n it did jus that-engine cold n she 10mm over the fins. Reasonably warm n deep sand so punished her for 25 clicks to really make sure she was hot! All is well in the world again ;)
    Cheers
    Oldscool and ohmygewd like this.
  2. rancher1 Husqvarna
    WA
    Good news a easy fix.
  3. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Daats good nooews Dr. Neeck.
    shawbagga likes this.
  4. Coyote Husqvarna
    Harrismith, South Africa
    WR300, WR250
    Yamaha XT660x
    :)FYI, I had a cylinder base gasket do the same thing on my 2013 WR300. Losing coolant and white smoke.
    Glad you got it sorted.
    Cheers,
    Coyote
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Base gasket loosing coolant? Really?!?
    justintendo likes this.
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Coyote was that the oem gasket or had u recently rebuilt top end?
    Think I'm gonna order a new rad cap too. $29 so cheap enough. Old one feels bit sloppy/loose fit n not sure if it's workin 100%. Lost a small amount of coolant on a near rear brake boiling single track last weekend(2nd gear corner to corner through the trees multiple laps-she was warm!!!). Only jus level/slightly under fins so maybe 60-80ml. Coulda bn from dropping it mułtiple times n tryin to get up ridiculous hills too:)
  7. Coyote Husqvarna
    WR300, WR250
    Yamaha XT660x
    Take Two-:confused:Getting worried and suspicious now--a day after I purchased my WR300, I had the white smoke , losing coolant issue. I then sent the bike back to the seller, who claimed "it was a leaking base gasket". The fault was cleared when I got the bike back, and now is playing up again with similar symptoms. I had a look now at a cylinder and there does not seem to be any cooling ports at the bottom.
    I wonder if I am sitting with a hair line crack and the "temporary fix" is no longer working?.
    It definitely was NOT the head 'O' rings as I replaced them with new ones myself.
    Cheers,
    COYOTE
  8. Coyote Husqvarna
    WR300, WR250
    Yamaha XT660x
    If you do a lot of slow , technical riding I suggest you switch to waterless coolant. It does not expand like water and also boils at 180 degrees C.
    Here in SA we buy Evans coolant, I know overseas there are motorcycle coolants that are waterless.
    To change the coolant it is a two step process-flush the old coolant out with an special fluid they sell, and then fill with the new coolant.It is non toxic as well.
