Dauer
I'm curious what your findings will be as well. I've been communicating with Willy from HPI and can commiserate, while he does always respond, occasionally it can take a few days and sometimes things seem to get lost in translation but HPI has been FAR more responsive and helpful than many other ignition suppliers. I'm in need of an ignition for my '92 WXC 360 and HPI says this: http://www.hpi.be/item.php?item=210R357 flywheel will work. The large diameter is spot on, however I'm unsure of the angle, a mechanic told me my taper angle is 6 degrees (not sure how to calculate) if that's the case the angle of the HPI flywheel will not work.
What got my attention regarding your post is the fact that you think the taper angle on your HPI flywheel while stated to be 4 degrees was actually closer to 6 degrees. I understand it is possible they sent you the incorrect flywheel and you're waiting on confirmation from HPI. I'll be interested in how things turn out. I also understand your frustration as I've been searching for a replacement ignition for my bike for nearly 3 months
. Good luck
. Good luck
