EarthX Install and Review
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by bigmo, Feb 15, 2014.
  1. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    This is indeed useful. I just checked the specs on my Battery Tender Jr.and it does indeed have desulphation. Looks like I'll be going with the Wallyworld or B&D route when I get my Earthx.
    Tinken likes this.
  2. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
  3. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
  4. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    quote="Johnrg, post: 443447, member: 11561"]Where did you find this info? Questions on a site I just looked at asking about desulphation said no...
    http://www.walmart.com/ip/Battery-Tender-Junior-Charger/15779492#Specifications[/quote]
    I just downloaded the pdf from their site. Go to their product page, click on the charger you own, then click on the help documentation page. Here's the page for mine as an example...
    http://batterytender.com/products/motorcycle/battery-tender-junior-12v-at-0-75a.html
  5. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    It does not state it has a desulphation mode, just that it alerts to a sulphated battery or a bad connection. Not sure how to interpret that :confused:
    Guess my BT jr will stay dedicated to my Audi and get the cheapo no limited brain function model for the two EarthX I have.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Jimmy250, Motosportz and Johnrg like this.
  7. Robster Husqvarna
    Sweden
    TE449 -11
    Superb answer. Thanks for that! I live only 100 miles from CTeks head office and development. Been there and those guys are VERY thorough. I still have an old charger of theirs that does not have the desulphating mode. Guess I will keep that one just in case I get an EarthX battery. =) Thanks for sharing!
    hillbilly likes this.
  8. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Ahh, I misread the pdf. It says the best way to eliminate sulphation is to prevent it. Then it says it doesn't lead to sulphation like other chargers. Well cool, cause I've got 2 of them.
    Tinken likes this.
  9. R_Little Husqvarna
    NJ
    My new Earth-X from ZipTy is working great.
    So is my gray case 4 yr old Turn-Tech 5aHr
  10. Motosportz CH Sponsor
    I went through 3 turn techs and they kept failing. I said never again on the lightweight batteries. Now I have a earth-x in my 511 with no kick start. So far so good. Tinken better be right :D
    reveille likes this.
  11. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    That sounds like my Ballistic EVO2 lithium history(nightmare). Swore I'd never go lithium again. May consider EarthX once I see them consistently last more than 2 years. Dropping weight up high is instantly noticeable, at least to me it is.
  12. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    The weather is colder in Mammoth right now and the Beta Is not starting on the same routine, choke on and 4-5 twists before button pushing. EarthX is doing fine with the extended starting efforts. Sea level starts in warmer weather are just 2-3 twists.
  13. R_Little Husqvarna
    NJ
    I must have a good one!
    It's over 4 yrs old and I never charge it and the bike sits for months at a time in the winter.
    Go figure!
  14. Motosportz CH Sponsor
    Buddy Jake has one of the earlier ones that is just shrink wrapped. No issues. Mine is the newer one with the plastic case and the negative terminals come loose. Known issue.
  15. Guoseph Husqvarna
    Alameda, CA
    FE501S
    Honda VFR800, KTM 525 EXC
    Where can i buy the extenders? Do you have to drill them out too?
  16. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    You can call us and we can get one out to you asap
  17. underwatersimon Husqvarna
    Pictou Co. Nova Scotia
    2015 Beta 350rr
    Direct from Earth X.
    Battery is still going strong by the way.
  18. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    At my last race the thing really shined for me. Lots of bottlenecks with carnage piling up and a few stalls on my part running hot and picking through rocks and other riders. Probably stopped and started the engine 20 times. In most cases to save gas as it was a 40 mile loop before the pits and the Earth X never missed a beat, never had a compression stroke battery killing dash reset, and didn't have to worry about getting going again.
    Daveb511, Tinken and Johnrg like this.
  19. Vustadumas Husqvarna
    2014 TE449
    Ducati 1198
    Received the Earthx today from ZipTy! Thanks for the quick turn around on the order! So, looks like I need the extenders to hook up the battery? Man, things were starting to come back together fast, knew there'd be a wrench somewhere down the line. Hah.
  20. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Extenders on a 449? Make sure you put one pad on the bottom of the battery and two on the side.
    Huskynoobee likes this.
