EarthX Install and Review
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by bigmo, Feb 15, 2014.
  1. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    You may also need to open up the terminals some as the Earth X bolts are slightly larger. I added the pad under the battery to bring it closer to stock battery height and just slightly rerouted the cables. I also put a pad on the retainer strap.
    Tinken likes this.
  2. Vustadumas Husqvarna
    2014 TE449
    Ducati 1198
    Yeah, looks like I need a 1/4 inch bit to chew through the connectors. EarthX said they have 5mm bolts as well, but don't feel like waiting on them.
  3. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    A rat tail file is what I used.
  4. ST Rich Husqvarna
    I used a step bit and went REALLY slow.
  5. Vustadumas Husqvarna
    2014 TE449
    Ducati 1198
    Yeah, that sounds like a better, more controlled option. Would suck to ruin my leads, hah.
  6. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    Has anyone needed to charge their EarthX yet?
    Mine has been sitting in the bike new for a week or more. (Since arriving from Zipty Racing :thumbsup:)
    Wondering if I should charge it some before the first use.
  7. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    Not me.... That is not much time at all. Both my bikes have sat for a month or two and both started right up and the batteries are 2 years old. Impressed with their stability to date.
  8. underwatersimon Husqvarna
    Pictou Co. Nova Scotia
    2015 Beta 350rr
    Good here to. Even after a couple of months.
  9. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    Good to hear!
    EarthX is in!
    Leaned the bike over to burp the coolant system and replace the factory cap with the CV4
    Almost threw the bike over the other way due to the weight differential of the EarthX :D
    Wow, the starter definitely spun faster! :thumbsup:
    engineerk9 and underwatersimon like this.
  10. River-Runner Husqvarna
    2012 TE511, 2012 TE310
    2015 KTM690 Enduro
    If you let the earth-x sit too long, there is a protection circuit that shuts the battery down so it doesn't totally discharge. It will appear dead when you try to start the bike - no click. When you put "most" battery chargers on the "protected" earth-x, it will not start to charge. The new generation chargers need to find "some" charge on the battery to start the charge process. If in the "protected" mode, you must put another battery into the charging circuit to prime the charger. Once the new generation chargers see a small charge, they start their charging cycle and all is good. The earth-x will come out of "protected" mode, and start your bike. This has happened over the winter with both our 511 and 310.
    engineerk9 and Tinken like this.
