EFI cleaning additive to fuel
Discussion in 'EFI/carb' started by 09Husky310, Dec 8, 2011.
  1. Matron Husqvarna
    Te510 2010
    Hello there, I had a similar problem with my Te 510. Had to rev the hell out of it to keep it running or it would stall.
    On further inspection I found that the decompression lever was slightly on when the handle bars were turn to the left.
    Problem rectified all good now
    ray_ray likes this.
  2. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    The very best & least expensive carb & efi cleaner is metholated spirits 500ml per tankful
  3. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    16 ounces per tankful?
  4. Motosportz CH Sponsor
    1. Denatured alcohol, also called methylated spirits or spiritus, is ethanol that has additives to make it poisonous, extremely bad tasting, foul smelling or nauseating, to discourage recreational consumption. In some cases it is also dyed.
    So you add ethanol?
  5. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Is this real? I thought the ethanol/alcohol is what's causing most of the issues. Just wondering.
