FE/FC FE 350 suspension tips
Discussion in '4st' started by TommyX, Aug 4, 2014.
  1. Fast1 Husqvarna
    Minneapolis, MN
    There must be different variations because the forks on my FE 501 kick ass. Superb for my terrain and skill level.
    fletchman45 and reveille like this.
  2. fletchman45 Husqvarna
    park rapids
    Yea its all good it may take awhile but I will have a detailed ride report. I am going in with and open mind. The double a guy that won the hare scramble series had stock valving and springs on his 4cs forks and jeff from halls is double a and does fine with them. I think they will be fine once dialed. All good...
  3. giannip Husqvarna
    Italy
    fe350-14
    TM EN300-10 - Honda CRE 250-06
    I have many problems with 4CS forks.... they are too soft and revalving and stiffer springs not resolve this bad sensation ....
    I have solved this situation with 2007 CRF Showa forks. Some works to adjust the clamps and Honda wheel axle with self made spacers and a specified brake adapter for continuing the use of Brembo caliper . Now is another world .... :)
    KXcam22 and fletchman45 like this.
  4. bowser Husqvarna
    FE350
    Does anyone have the stock stacks for a 14 FE350?
  5. tuonato Husqvarna
    GREECE
    FE 350 2015
    has anyone tried Kreft Moto’s 3 way adjust system for 4cs?
  6. Chums Husqvarna
    I'd like to discontinue my account
    I've talked to kreft a couple times and I have no doubt that they do great work. He was putting a adjustable base valve in that gave you high speed and low speed adjustment which ment the bottom of the shock did one thing and the top did the other while keeping the rebound on the top of the other fork. It sounded like they were going to do what zipty does and put comp on the bottom and rebound on top now. That being said I think zipty has a Better price and is probably the route I'll go, but it seems they take some time to complete.
    reveille likes this.
  7. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Kreft uses Jeremy Wilke's parts from MX-Tech which is local to me.
  8. bowser Husqvarna
    FE350
    pretty sure Chums is right and krefts setup is now only 2 way, with both legs having rebound on top and comp on bottom.
    Heard good things about it.
    I just valved mine different again today, trying something pretty different this time, still just using the OEM parts
    Chums likes this.
