Finally found the crash damage! Rear sprocket.
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Cosmokenney, Sep 30, 2014.
  1. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    I do not recall. That is likely a very high quality chain. You do not have to spend 100$ on a chain, you could get something like this;
    http://www.amazon.com/RK-Racing-Cha...&qid=1412289751&sr=8-16&keywords=rk 520 chain
    not sure if thats the exact model but I have used 3 RK chains on supermoto bikes over the last 2 years (I have had like 4 different bikes) and no issues. RK is available at a local motorcycle shop like a few blocks away so that is what I purchase.
    Only reason I say to replace the chain is because the stock chain is absolute garbage and there is many threads on it, I had tons of problems with mine losing tension then getting too tight and having kinks all in the frst 500 miles. Also if the sprocket and chain got whacked then the wobbly sprocket run, could have damaged it and better safe then sorry.
    That is all I got for ya :) I cannot remember the length I purchased I think 118 which was a few links long.
    Cosmokenney likes this.
  2. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    + 1 For RK.
    I've fitted 4 or 5 of them in a row & have had zero trouble.
  3. rancher1 Husqvarna
    WA
    I like an o-ring chain, the plain chain stretches wat too fast, even the RK stuff !
  4. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Take a look @ 520 ERV3 Gold.
    robertaccio likes this.
  5. Dana44 Husqvarna
    2012 TE310
    If you still have it send that sprocket back to Rethal's warranty department and just tell them you bent it riding.
    Bent my Rethal bars, sent them in with a note. They shipped me a brand new set.
  6. Motosportz CH Sponsor
    Hey, you talkin to me? :confused: :)
  7. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    no you just adopt sloppy old bikes with bald tires and cheapo brake pads that need a good home. feed them clean them up then proceed to beat on them...
  8. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Me personally, I draw the line at sloppy loose girls. It's the combination of the two. But if their not sloppy, or not loose, then they're a maybe ;)
