jsleeper
Today, I was able to finally tune the bog out of my wife's WR125. After being inspired by Walt, I opened up the powervalve. I tried a cheapo spring from Ace. While this did not cure the bog, it was fun to have a wheelie-popping hit when the PV opened.
So, the next thing I did was raise the needle to the 5 clip from the top (as high as it can go). Then I ground the ends of the origional powervalve spring a bit. Lastly, when I put the linkage for the powervalve back together I pushed the adjuster screw on the linkage as far up as possible. My thoughts on this is that the PV will open just a bit sooner, or even stay open just a bit.
I took the bike out today and it ran perfectly. No bog. Really, really strong on bottom. It will pull in 6th gear from almost a chug until the PV opens.
Since i am a novice at jetting, nonetheless, PV stuff. I have to think the problem is as Walt described: the PV sealing too tight. I think grinding it, or figuring out a way to have it slightly open helps the bike run better. Just my thoughts.
JS
JS
I just re-read this paragraph and it makes so little sense I am roflmao. I know what I mean.
