All 2st first husky!!
Discussion in '2 Stroke' started by Travis Thompson, Apr 8, 2013.
  1. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
  2. Travis Thompson Husqvarna
    1991 wxe 260
    1978 yamaha xs750 special
    yah just saw that so if a 260 head ever comes on im gonn a get it so i can use o rings
  3. 2premo Husqvarna
    Northern NV
    probably the same head
  4. Travis Thompson Husqvarna
    1991 wxe 260
    only thing id be concerned about is the cut out and if the piston would hit the edges
  5. 2premo Husqvarna
    Northern NV
    I stand corrected it is a different head bore difference of couple mm
    need to ask someone if you canadjust the combustion area to work
  6. Travis Thompson Husqvarna
    1991 wxe 260
    yah though it looks as if though my cylinder was resleeved....does anyone know what the stock bore is of the 260 so i can double check. Thanks
  7. Travis Thompson Husqvarna
    1991 wxe 260
    im thinking of dual sporting it soon and it has 14/48 gearing. would it be ok to got to like a 40 in the rear. ? i can barely cruise at 50 but it seems like it could handle it not sure. Thanks
  8. 2premo Husqvarna
    Northern NV
    My 360 has 15-48 gears in 93 stock
    Is your bike pulling full rpm's
    Does yours have a six speed?
    What are the stock gears for your model?
    And jumping that many gears is huge
    Try a 15 on the front
  9. Travis Thompson Husqvarna
    1991 wxe 260
    Ok....14/48 still easily pops wheelies real easy just seams like I could really Change it...I will try the 15
  10. Travis Thompson Husqvarna
    1991 wxe 260
    what is a good but not pricey air filter out there and are there any others that will fit it other than stock.
  11. 2premo Husqvarna
    Northern NV
    Cheap filters don't save in the long run
  12. chris anders Husqvarna
    2002 CR250 , 2002 CR125
    2003 Suzuki RM250
    http://www.athenaparts.com/eng
    check these guys out for gaskets,Ect. They have alot of husky gaskets , bearings, that i couldn't find elsewhere-they are in italy,so shipping takes a couple weeks.
    good luck!!
  13. Travis Thompson Husqvarna
    1991 wxe 260
    Ok I will...thanks might have to get a left side crank seal cause think transmission oil is getting through..
