Big Timmy
Who said that ? You guys can sure read into things can't you. It's always a play on words isn't it?
I was referring to the amount that the production welders are probably making doing this work for these companies.
What I am saying is a one off custom prototyped full system for say a bike that has had an engine swapped for instance as an example. A production pipe for that same engine could be measured and duplicated to the same length and specifications to fit that swapped chassis and be one of a kind. This being done on a bike that a production pipe does not exist, for instance. This could still be done and can be made for what a production full system costs. Without the need for all the testing.
When many of the production slip-ons for 4 strokes fit the stock headpipes you can't tell me they are totally maximized to the point that they aren't still a compromise. All they have to do is show an improvement over stock and most people are happy. Many people expect it to be and want it to be louder.
I've seen some big name 2 stroke pipes and silencers installed on dirt bikes that although they were much louder than stock, the bike wasn't even able to pull the next size main jet to get a clean burning plug reading. This was on fresh rebuilt engines too. What does that tell you about all the company testing? If an aftermarket system is way louder but it won't even require re-jetting to show an improvement other than how damned loud it is. You might as well go back to the stock system. Your neighbors will thank you for it.
