250-500cc Front wheel spacer size.
Discussion in '2 Stroke' started by Makntracks, Oct 14, 2016.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Ha I'd like to take credit but no nothin bout machining or lathes jus the boys at work.
    I got rears made 17mm long(16.7mm u said hurky) as don't think 0.6mm make SFA difference n jus easier with whole numbers. He did pretty good job but I'm a fussy prick n one flange is 4mm thick n the other 3.5mm. Again will make SFA difference. Edges could do with a little more chamfering to take sharpness off a little. ID n ODs spot on tho. Not bad for cost of half a dozen stubbies at the bar!
  2. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    Well, my old spacers did measure 16,7mm for sure, but I also find that a strange value, I think that they simply did wear 0,15mm on each side...
    I also don't know what stainless were mine made out, after some month of usage I can already see some marks were the lip seals... A hardened steel would probably last longer but will suffer corrosion ...
    Cheers..
  3. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    They'll still wear(everything does) but a lot slower than the ally/cheese oem spacers
  4. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    Knocked out my first lathe project, thanks for specs on the spacers so I didn't have to pull my wheel to measure it :D
    SS
  5. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Good luck fitting it.
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Those flanges look very thick(;)) gotsa. There's a gap between flange edge n seal jus not sure how much. Worst case u may hav to turn em down a mm or 2. Good stuff
  7. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    I stuck them in a spare wheel and it looked ok but if I have to narrow up the flanges that's no biggie.
    shawbagga likes this.
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I like a flange a bit on the tight side, should be fine
  9. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Couldn't help yaself could ya juicy:)
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Dunno what you mean, it will help keep dirt out being that close to the rubber seal
  11. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Apologies my good man I thought you were being facetious.
    I'm not 100% certain u weren't tho! ;)
    juicypips likes this.
