250-500cc GasGas piston in WR 300
Discussion in '2 Stroke' started by Johnnymannen, Jun 6, 2010.
  1. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    You should contact WISECO about running off some domed units, since you are carrying the stock piston.
  2. TROFFER88 Husqvarna
    Camas Wa
    I second the motion
  3. zilly Husqvarna
    Yakima
    09 wr300, 04 cr125
    That's what I like to hear! :cheers:
    Maybe if you could give me some bank account #'s I'll just start having my paychecks directly deposited into your account!
    At the speed I ride and the fact that I am currently laid up I am a long ways off but nice to know I have a spot to go when I need to. Thank you.
  4. Motosportz CH Sponsor
    MotosportzMike will look into it and see if it is a possibility. :excuseme:
  5. baz Husqvarna
    Canada
    You should take a look at a 1986 trx250r big bore piston. It has the same pin and deck height as the gasgas but with the WR intake shape.
    Gasgas piston on the left and 66mm trx250r piston on the right. Wossner trx250r big bore piston part# is W845PS. Wiseco also make this piston gut i can't find the part#.
  6. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Good find. Just need a 72mm Honda piston.
  7. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
  8. TROFFER88 Husqvarna
    Camas Wa
    Are you going to try this out ?
  9. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yes, I'll have to get one. I need to at least see if it will work.
  10. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    I've got one on order.
  11. vntgmx Husqvarna
    NJ
    I must say having now ridden my '10 WR300 4 times at the MX track I don't get all this ignition,pistons,carbs etc talk. The bike has plenty of good and usable power with the stock carb,pipe etc and at the most maybe you can tweak the jetting to your liking but I can't see anyone needing or being able to use more power unless you are a true front of the pack "B" level or expert rider. Older weekend warrior types are just making it harder on themselves trying to extract more power from the engine and your money would be better spent on suspension and ergos.
    Tinkering is one thing but I can't imagine especially for woods riding that unless your name is Kearny,Davis etc that more power is going to make you go faster in fact I'd say it would actually do the opposite as you'll wear yourself out quicker.
    All I've done is adjust the air screw set the idle and I'm running race gas at 32:1 and it starts easily and runs great. I've had no trouble keeping up with similiar skilled riders as myself on their new 450Fs so it's not lacking engine in stock trim.
    Either way have fun tinkering but I just wanted to add my personal take on the WR300 as I think from reading this site that folks who are researching a WR300 would get the impression that in stock trim it's not a good ride and that couldn't be further from the truth for the average joe.
  12. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    No, you're right, it's killer. I can't get over how high I can run up in the gears in technical sections. With that said, I'm not sure what I'm doing either. I guess it's a sickness of sorts.
  13. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Cancelled my piston order today and re-ordered the Race Head. I'll reconsider the piston when it's time to replace the stocker.
  14. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    2009 RMZ450 2005YZ250 2001 EXC300
    How much for the race head????
  15. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    How is it different from stock???
  16. racer726 Husqvarna
    Unionville, MI
    The race head was a little over $100. It ups the compression, but you can still run pump gas. Good investment in my mind.
  17. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    Where did you order your race head from?
  18. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Hall's. Like racer726 siad, it just seems like a good investment.
  19. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
    any change to the squish band
  20. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    I can give you more inof when I get the new head. I'll try to post pix of both.
  21. motomaniac Husqvarna
    Kamloops BC Canada
    2010 WR300
