Gear lever question...
Discussion in '4 Stroke' started by 7point62, Aug 31, 2009.
  1. rabskyline Husqvarna
    Sunshine Coast,Queenslander !!
    2014 te250r
    Yer maw !
    height on my 510 is fine.. just think the end part is too short.. barely catches my boot ! i'd like it 3/4 inch longer ! so i can click it without thinking about turning my toe in a bit.. annoys me to hell !
  2. HUSQVNA Husqvarna
    Arizona
    Anyone have the specs on how much longer/wider this unit is vs. the stocker? Just ordered the Hammerhead shift tip extension off a CRF to put on (20mm/3/4" longer), but if this is going to give me the same benefit, much rather go this route and keep the stocker as a spare.
  3. HUSQVNA Husqvarna
    Arizona
    Got my answer from the manufacturer. It's a direct replacement to the OEM. Guess it's not what I'm after!
  4. rabskyline Husqvarna
    2014 te250r
    Yer maw !
    Nah. Me neither.. I want further out, not longer..
  5. HUSQVNA Husqvarna
    Arizona
    I put the Hammerhead 20mm extension on last night off a Honda CRF and it gave me exactly what I was after, MORE ROOM!! Required a bit of modificaiton to the stock lever, but nothing major. Just drilled out the lever for the larger diameter pin, added one washer/spacer to the set up, and used the stock spring/ cut to size. Looks like it was made for the bike, and more importantly, works like a charm.
  6. rabskyline Husqvarna
    2014 te250r
    Yer maw !
    great..will have a look at that !
