250-500cc Gearing for single track on WR300
Discussion in '2 Stroke' started by hesutton, Apr 6, 2015.
  1. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    Hey guys i hope im not hijacking the thread to bad but im at 15/48 and i can just about hit 45mph! does that sound right? i thought id get a little more out of her when i changed the front sprocket. btw those trails do look badass:thumbsup:
  2. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Something is seriously wrong if you can only go 45 with a 15T front sprocket.
    shawbagga and Glenn haynes like this.
  3. 24valvecummins Husqvarna
    2014 wr300
    kdx200 yz250
    Thats what I was thinking. I know my lectron is running rich and I'm having trouble finding the sweet spot
  4. Brian Scott Husqvarna
    Bainbridge Island, Washington State
    '11 WR 300
    '01 CR 500R
    What Eagle free said. You should be able to do 80 or 90 mph with that gearing on a 300. I've pulled over 70 mph with 13:50 on my 300 (and had smoke coming out of the silencer afterward from burning off all the spooge in it). Hee hee.
  5. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    I also run 13:50 most of the time for tight single track. 14-50 is also great all around. The motor has plenty of pull to still lug and not stall down low and requires less shifting as it spreads out the gearing a little. I used to run 14-50 or 14-48 in the desert without any issues at all.
    Brian Scott likes this.
  6. Brian Scott Husqvarna
    '11 WR 300
    '01 CR 500R
    I should add that I run a Rekluse Z-Start Pro, high comp head, gnarly pipe and the kehin PWK ASII, so plenty of bottom to mid for the 13:50 and 14:50 gearing w/no fear of stalling. It lugs like a tractor (or one of the 4 strokes bikes I've heard about :)) when I want it to.
  7. mikebru Husqvarna
    Ocean County, NJ
    2009 WR250; 2012 TE449; 2005 TE450
    24Valve I just replied to your other thread. Maybe it will be helpful.
    Mike
  8. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    2021 Sherco 300SE 2002 Honda CRF450
    The 12 front and 50 rear sprockets arrived the other day from Supersprox. Work's been busy, so no time to try them out yet. I'll start with the 12/48 combo first, then try 13/50, and finally 12/50. I'll have little time to ride before my trip to West Virginia, but I'll eventually post back with my impression with the different cogs on the WR.
    Thanks again for all your input.
    Heath
