Hard Starting with Booster Plug
Discussion in 'TR650' started by Kenneth Webb, Jan 20, 2013.
  1. DeLewis Husqvarna
    Melbourne, Australia
    To avoid starting a thread, I'm offering my slightly used and working Booster Plug free to anyone who wants it. Just need to pay the postage. Like most people, I found it worked well for a bit then seemed to be tuned out by the ECU. But who know, it may work a charm for others. Just PM if interested.
  2. wferrari Husqvarna
    TR 650 Strada
    V-Strom
    I'll send the accelerator module free of charge to anyone in the EU, just PM me. I believe it works on the 650GS as well. Anything DeLewis said about the ECU applies here as well.
  3. danketchpel Husqvarna
    Camarillo, CA
    Terra 650
    Moto Guzzi, Ducati, Beta
    Thanks for the info Roger.
    What I need to do is contact DynoJet to see exactly when the PC5 kicks in during the start up routine. I already know the AutoTune doesn't even come into play until the bike is running.
    The PC5 does offer a cold start map option if you connect the engine temp sender to it, which it's currently not. That is probably worth the effort, but I need to see if the OEM temp sender works on a 0-5v range, most likely it does.
    I have subtracted a lot (-25, whatever that value truly is) of fuel from the lowest rpm ranges (500, 750, 1000). It's basically much too rich during the first 2-3 seconds as you pointed out.
