I Haven't run it dry, but I have put 13.7 litres in (that's 3.6 US gallons) and it was still running.
Well, it is a more complete benchmark for you to compare for next time
Good work
Though I couldn't help notice you used 91 octane fuel. The specified fuel for the Terra is 95 octane due to the higher compression ratio. Any noticeable pinging?
So to summarize (I rounded to the nearest gallon):![]()
Ran out of gas while running 55 mph down the highway….no sputter….no cough….simply gave up without a fight at:
If you do the math, it seems these two gauges deviate in readings by about 1 mile comparatively.
****Edit***just realized why the numbers are slightly off. I turned off the bike to take the photo when the fuel light first came on. When I restarted, the fuel light was off....and it took about 1 mile before it came back on. The Reserve Gauge zeroed and started counting over when the Fuel Light came on again.
I happened to be 2 miles from a gas station when she died. I poured in the 2.0 gallons of fuel from my Rotopax, and the bike fired right up on the first push of the magic button…..no sniffles….no wheezes….no problems.
Low fuel light came on a 167 (166+1 mile for the light to come on again after pic was taken)
Total miles on a tank was 206 (not sure when the pic was taken, presumably after you got to the gas station 2 miles after you put fuel in, in addition it takes 1+ miles to make the low fuel light go off before the trip odo can be displayed again)
about 40 miles showing on the trip odo when you ran out of fuel
Correct?
If so, it appears your numbers might be the highest posted yet. (my low fuel light comes on at 161 to 165)
This surprised me, as I was expecting more. Anyway, 2.0 gallons + 1.74 gallons = 3.74 total.
Why have I been thinking the tank holds 4.2 gallons? Wherever did that number come from? I'm not sure I ever read any literature.....and probably didn't studying the manual (Shhhhh....don't tell anyone). Now, I'm going to have to look into the matter more carefully.
HF
Negative.....I took photos on the spot I ran out of gas. Precisely 208 miles on Trip. The Reserve gauge reading needs 1 mile added to it to get back in sync with Trip Meter....rounded off, it's 166 + 42 = 208.
I zeroed my Trip when I poured in the Rotopax fuel to resuscitate. And it read 2.3 miles when I arrived at the gas station to top off my tank with another 1.74 gallons.
HF
