TE/TC Hearing detonation in front of motor
Discussion in '2st' started by HS507, Jun 13, 2016.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    Well, mixing Dragon fuel (true 95oct) 25% or so mix in with pump gas and last 2 rides its quiet. Im 2 out on AS
  2. HS507 Husqvarna
    NE Ohio
    Te 300
    First i
    miss quoted MJ, its a 168 (as per JD at my alt), and yes i think you were right i mixed 95oct in and its now quiet last ride and 1 race. Ty
    lankydoug likes this.
  3. HS507 Husqvarna
    NE Ohio
    Te 300
    And i also misquoted needle color, im on Red. I keep looking at the te250 side of my instructions, sorry again guys for confusion on my first post.
  4. BSBen Husqvarna
    2015 TE300
    2004 Sherco 2.9
    Well, I got a pail of VP 110 and ran it for a couple of hours today - exhaust smells GREAT, but I digress... I ran it under conditions that would usually produce the knock and I heard nothing at all. So far, it seems like an octane thing. I really don't want to buy 5 gal jugs of VP at ~$70 a pop, so if this really addresses my problem, I'll probably try the 100 octane pump gas I can get around here. This weekend's hare scramble should let me know for sure if it was fuel, and I'll post my findings.
  5. HS507 Husqvarna
    NE Ohio
    Te 300
    It was octane issue in my bike. I used 95 dragon fuel, changed to 110 race pump gas, plug is light brown instead of wet black, no spooge on pipe after race, knock went away.
  6. lankydoug Husqvarna
    MO
    WR
    TM 300en
    I believe that better fuel has a lot more benefits than getting rid of a death knock. Longer shelf life without additives, not corrosive, starts easier, doesn't dry up rubber "O" rings and harden plastic parts, doesn't varnish up while sitting for short periods, can be tuned on the crisp edge without triggering detonation. To sum it up, we are buying and riding performance engines intended for racing so using race fuel seems to be common sense. I attribute good fuel to longer engine life and a cleaner combustion and exhaust. This means more riding and less working on your engine and fuel system. I'll gladly pay an extra $1.50 per gallon for that. (here in MO pump 93 is $2.49 and LL100AV is $3.99)
    juicypips likes this.
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Pmsl $2,50 for a gallon!?! I pay £1.28 per litre for shell VP nitro. Lol you guys get far more for your money!
  8. BSBen Husqvarna
    2015 TE300
    2004 Sherco 2.9
    Wow - $2.49/gal is nice. The 100 up here (Chicago area) is about $7/gal. Better than $14/gal for the VP though, so I hope 100 does the trick too.
    Incidentally, I found another station with 110 at the pump, but it says "leaded race fuel". I believe the VP 110 that bought was leaded (TEL). Can I just use the "leaded" pump gas? Any danger there?
  9. HS507 Husqvarna
    NE Ohio
    Te 300
    What oct rating is it?
  10. HS507 Husqvarna
    NE Ohio
    Te 300
    Is this aviation gas? Thats cheap. I gotta look into this. I heard boat marinas will sell ethanol free 95oct
  11. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    That's 99ron straight from the pump.
    At most shell garages in UK.
  12. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    Av gas is for low rpm engines not high rpm motorcycles.....
  13. racemx904 Husqvarna
    owenton, ky
    Leaded gas is fine
  14. HS507 Husqvarna
    NE Ohio
    Te 300
    Lots of opinions about this av110ll, i hear its better than pump but race gas is best. But, av wont hurt. Just some write ups im reading
  15. HS507 Husqvarna
    NE Ohio
    Te 300
    I would just mix it like i do with race gas, instead of straight. Av gas is low lead
  16. racemx904 Husqvarna
    owenton, ky
    Do what you want.... Watch what you read on the internet... Make sure to research.... AV gas is meant for low rpm airplanes and different burn rates... I'll get with my vp and f&l guys to get the info...
    If you are going to mix just mix race gas and pump....
  17. lankydoug Husqvarna
    MO
    WR
    TM 300en
    The AV100LL is aviation fuel and I buy it at our local airport. I've also used VP110 which runs better in my YZ450 that I re-mapped to take advantage of the better octane but the AV100LL and the VP110 run about the same in my WR250 Husky. I've heard a lot of different things said about why you shouldn't run AV100LL but it has never been backed up with anything other than opinion.
  18. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Where did you get this information?
  19. racemx904 Husqvarna
    owenton, ky
  20. 84scrambler Husqvarna
    mid Florida
    Remember gas you buy at the corner station is made to burn in new cars , not dirt bikes that are made to race and dam sure not a 2 stroke engine. Would'nt slower burning gas require a more advanced engine timing? Hotter gas I think would burn the best closer to tdc.
    I too like the vp brand its expensive but I think its worth it also. (no doubting about fuel any more)
